2002 Cape Cod Eurovan
60vwnewengland
Twin #2
60vwnewengland is offline
PostPosted: Sat May 03, 2025 4:13 pm    Post subject: 2002 Cape Cod Eurovan Reply with quote
Hey folks, I’m looking at this 2002 Eurovan. The owner doesn’t have a price in mind, but it’s non-op. Had starting issues when parked. There’s a pile of paperwork in the van from 2016. New thermostat, alternator, brakes, crankshaft sensor, starter, and exhaust. I guess it was still leaving the current owner stranded…
I don’t know a lot about eurovans, but I’ve done enough work on all year buses and modern cars. Not sure what’s wrong with it.
The body looks to have typical cape cod crust. It’ll need new brake lines (hard and soft) brake parts, battery, ignition, trans and oil change. But what else should I look for? I couldn’t really see the underside, it’s a little snuck into the ground.
What should I offer to the seller to take this off her hands?
77 Westy - Cape Cod Sage
70 Beetle
71 Super Beetle
RIP TheWalrus (Big Jack) 1988-2024
HeyCrutch
HeyCrutch is offline
PostPosted: Sat May 03, 2025 4:21 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
As a comparison, last year I purchased a 2003 GLS that was in better shape than the one you're presenting in this post, but did have advertised transmission issues, for $1000. The seller had advertised it for $1500. I'm using it for parts.
-2003 EV MV Wk - Forest - 51k
-2002 EV Camper - Ghost - 82k
-2003 EV GLS - Fluffhead - 176k
-1997 EVC - 12vVR6 (SOLD 5/2025)
paddygarcia
paddygarcia is offline
PostPosted: Mon May 05, 2025 7:38 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
Not kidding: unless you need specific parts off that one they should pay you.
Abscate
Abscate is offline
PostPosted: Mon May 05, 2025 11:15 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
That’s a pretty big green box of Charlie Foxtrots
VanGeek
VanGeek is offline
PostPosted: Mon May 05, 2025 11:29 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
What you already know and can see is very significant. A lot of work and cost.
What you don't know and see is likely worse -- especially if it's been sitting in the mud.
Not sure if Paddy was joking or serious. But me thinks you should pay little or nothing for it, because a Eurovan MV tin top in excellent condition isn't worth a ton (under $10K?), and whoever takes-on this project has a lot of mechanical work and expense ahead -- likely body and rust as well.
paddygarcia
PostPosted: Tue May 06, 2025 4:25 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
Very serious, for all of the concerns you expressed.
Enough water inside to rust the front seat base (!) and a coincidental mysterious electrical issue. Hmmm.
Obvious heavy rust bubbling in many places, meaning there's lots that we're not seeing. Piles of leaves that don't bode well for the fenders. I'm from the Northeast and not terribly afraid of rust but there's a whole lot of it here.
Shot headliner. Needs a full set of brake lines made, which is a lot of lines to make on one of these. And then there's the dice-roll on an unknown and untestable trans.
As a haul-away parts source it's worth some effort but IMO not any money. Get it running, test the trans and if you got lucky buy a nice one with a bad trans - they're out there.
60vwnewengland
Twin #2
PostPosted: Tue May 06, 2025 4:47 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
I made a list of parts needed from Rockauto, tires, and miscellaneous, I'm estimating it’ll cost about $2500 at least to get it going down the road. That’s if there no hidden engine or transmission gremlins.
We’ll see. Going to bring a jack with me to try and get a better look at the underside before I make an offer.
Thanks for all the advice folks!
70 Beetle
71 Super Beetle
[email protected]
samscholz96@gmail.com is offline
PostPosted: Tue May 06, 2025 5:41 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
My 2001 WKR spent much of its live on Cape Cod
There is rust everwear but not to bad, bubbles, some rotten parts.
Been going over it with POR 15 when I have pices off as I fixed it.
2001 eurovn weekender 207k fresh batteries
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue May 06, 2025 5:44 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
Wow, you turned into an old man. What happened to the kid at Litchfield?
The avatar is classic.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
60vwnewengland
Twin #2
PostPosted: Tue May 06, 2025 5:50 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
I know… that was 20 years ago. This Eurovan was probably at the shop getting fixed for an electrical issue in 2006…
70 Beetle
71 Super Beetle
EuroTec
EuroTec is offline
PostPosted: Tue May 06, 2025 7:36 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
FWIW I would just walk away from that one. Rolling Eyes
If you feel inclined to take on a "project of unknowns" I wouldn't pay any more than $1K for that thing. You're in for more work than you think.
By the way, retired euro mechanic speaking here. Wink
If it ain't broke, don't fix it!
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
obnoxiousblue
obnoxiousblue is offline
PostPosted: Wed May 07, 2025 7:34 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
And you turned into an older man...
But to the point... Eurovans are great fun - when you have a good one.
If you get a bad one, it is a horrible experience all around.
If you get this cheap - as in so cheap that if it is a wreck you can part it out and get your money back - then great; take the leap and give it a shot.
But if you're over $3-4k then walk. You can find a better van for comparable money.
Furthermore, you may actually want to look at a pop top. If you're planning on getting back into the camping game, you will probably outgrow fast.
All told there will always be vans for sale. But these aren't easy to sell. So if you are going to buy in, you might actually get hurt more on what you lose at the time of resale than what you put into it now to get it started.
I'd suggest getting into a Eurovan that you plan to keep and use for a while.
Mike
1964 Beetle
2001 Eurovan Camper
SambaBurnsRed
SambaBurnsRed is offline
PostPosted: Mon May 12, 2025 10:46 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
Salvage eg$500 ish.
Fuel system is likely gum, depending on how long it sat
Probably needs a trans rebuild too.
Heater core (they are biodegradable)
Lot of work but you get new parts
jjvincent
jjvincent is offline
PostPosted: Tue May 13, 2025 2:30 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
What I find is that people just park perfect Eurovans in the grass and then forget about them. There's nothing wrong, they just were busy doing other things and that Eurovan just got lost in the shuffle. So, it sounds like you just need to install a battery, fire it up, take it home, throw on some ceramic coat and you have a perfect vehicle.
Just so you know, parking vehicles over grass and especially in the NE, just preserves the undercarriage. Moisture is like it is for your skin, it keeps youth. All of this talk about rusted out undercarriages and brake lines is is bull hockey. It's perfect under where you can't see it. Just look at the shiny paint and that's automatically what they rest looks like.
Plus, never take it to a shop and have them throw it on a hoist to look at the undercarriage. They will tell you it's terrible. Yet those guys are itching for a Eurovan and will snatch it up for $100.
samba415
samba415 is offline
PostPosted: Wed May 14, 2025 5:07 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
At first blush, I'm reminded of Sir Robin and "run away", but there are some great parts to harvest here. ESP/steering angle sensor is worth the purchase all by itself.
Old stable: '63 Baja, '69 Square, '72 Bug, '65 & '67 Samba, '73 412 wagon & 2dr 4spd
Current: '04 Golf TDI, '03 Weekender
60vwnewengland
Twin #2
PostPosted: Sat May 24, 2025 1:42 pm    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
A little update, I offered $800. The seller shrugged, and made a comment about how it’s worth more than that. I handed her the recent CL and TS ads that list similar non-op eurovans at $1000. Then I gave her my RockAuto parts list that, new tires, etc. was about $3k and said, these are the parts I’d have to buy to get it going down the road. And told her in all honesty, these vans aren’t worth a lot. The owner shrugged it all off and said she needed to think about it. I told her, you have my number.
I’m not going to pursue, it does seems like a lot of work, not sure I’ll have the time to work on it.
70 Beetle
71 Super Beetle
jjvincent
PostPosted: Tue May 27, 2025 11:47 am    Post subject: Re: 2002 Cape Cod Eurovan Reply with quote
Makes sense. That EV will be worth lots down the road. So, it's better for the owner to keep it as an investment.
Case in point. This past weekend I helped a friend of mine get a 72 Bus. It was parked at an old farm for years. He made an offer on it 3 years ago but the owner "had to think about it." A For Sale sign on the property. Got in contact and found out her dad died and she got the property. So the deal was this, she had the title and would sign it over if we removed it from the property. So we did and now he has enough for his next project. At least busses are a piece of cake to work on and get back together.
I always wonder, what price was he looking at or was it where nothing was enough and he'd rather die looking at his Bus just dreaming of it's value.
