balljoint Samba Member
Posted: Sat May 10, 2025 6:06 am Post subject: Flipping rear trailing arms |
Anyone has any proof of this being done to reduce negative camber on a bus? _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Sat May 10, 2025 9:10 am Post subject: Re: Flipping rear trailing arms |
what steps have you taken to reduce negative camber on your bus and what are the measurements now? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Sun May 11, 2025 7:50 am Post subject: Re: Flipping rear trailing arms |
I have 3.5 horse shoe plates and one outer spline down. Looking to get a degree wherever I could _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
SGKent  Samba Member
Posted: Sun May 11, 2025 2:27 pm Post subject: Re: Flipping rear trailing arms |
you might have better luck searching thru this thread, and asking here.
Lowering a Bay _________________
George Carlin:
Posted: Tue May 13, 2025 5:53 am Post subject: Re: Flipping rear trailing arms |
So I put new bushings in the arms bolted them in place on the same same side, one flipped obviously, and they measured out the same with an angle finder so I guess it's not a "thing" when it comes to busses. Don't believe everything on th interwebs  _________________ It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7857 Location: Santa Cruz
Posted: Tue May 13, 2025 8:40 am Post subject: Re: Flipping rear trailing arms |
Nice work.
Good to have someone try IRL.
Sounds like it's time for a torsion raise?
Saw one once where they converted to swing and just raised the trans...
The KCW forums used to have a few really dumped buses with extensive how-tos on severe lowering.
C-notches, etc.
That site is gone now but snapshots are on the wayback machine.
Look around about maybe 2011 or so..? _________________ Bus Motor Build
It does not exist! |
