late fan shroud removal question
SGKent Premium Member
SGKent is offline
PostPosted: Wed May 07, 2025 6:04 pm    Post subject: late fan shroud removal question Reply with quote
fan shroud
Q. Is it possible to safely pull a late fan shroud on a late 75-78 2L without bending studs or damaging something?
I have all the tin off around the shroud, but the shroud needs to come straight towards me to clear the studs, and the late heater boxes hold in the bottom. If I try to rotate the shroud forward it takes more pressure than am comfortable with, and the studs are too deep and too short to successfully double nut it. I tried using a loose 12 point socket on the studs with double nuts, but can't keep enough torque between the nuts - and I suspect those studs are in there pretty good after 45 years of steel and aluminum/magnesium being in love.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
busdaddy
busdaddy is offline
PostPosted: Wed May 07, 2025 8:47 pm    Post subject: Re: late fan shroud removal question Reply with quote
Short answer is no, not without removing the studs.
Unless you can split the shroud in place, that might buy you enough movement in the heat exchanger inlets to get off the studs, I've never tried since it looks like it'd be a serious PITA.
Know anyone with a portable welder?, weld the nuts on the studs and the slipping problem is solved.
Слава Україні!
SGKent is offline
PostPosted: Wed May 07, 2025 9:56 pm    Post subject: Re: late fan shroud removal question Reply with quote
Thanks Mark. I found your 2007 thread facing the same issue. Now I don't feel so bad. I will just drop the heat exchangers. That seems easier than fighting with the studs.
George Carlin:
1971 deluxe (sold)
1977 deluxe
Wildthings
Wildthings is offline
PostPosted: Thu May 08, 2025 4:12 am    Post subject: Re: late fan shroud removal question Reply with quote
In the good old days when these things were new and parts were plentiful, some mechanics would just cut slits in the heat exchanger tins where the exchangers slip over the shroud and bend the resulting tabs down and out of the way so the exchangers can be pulled straight back like the HXs were not there. Handy trick if one seals the area back up well as things go back together. Never cut the slits myself but have benefited when others have previously done so.
VDubTech
VDubTech is offline
PostPosted: Thu May 08, 2025 6:43 am    Post subject: Re: late fan shroud removal question Reply with quote
100%, yes you can pull the shroud without damaging anything AND without removing the heat exchangers. it'll pull forward enough to clear the studs then lift it up and out.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
SGKent is offline
PostPosted: Thu May 08, 2025 8:20 am    Post subject: Re: late fan shroud removal question Reply with quote
thank you
George Carlin:
1971 deluxe (sold)
1977 deluxe
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu May 08, 2025 10:31 am    Post subject: Re: late fan shroud removal question Reply with quote
I’d love to see photo/video evidence of that.
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
timvw7476
timvw7476 is offline
PostPosted: Thu May 08, 2025 11:30 am    Post subject: Re: late fan shroud removal question Reply with quote
Yes. I suppose IF the alternator is removed to balance it, & the oil filler is also removed right down to the flange at the crankcase ??? Perhaps ?
aeromech
aeromech is offline
PostPosted: Thu May 08, 2025 7:45 pm    Post subject: Re: late fan shroud removal question Reply with quote
Sounds like you’re feeling good Steve
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent is offline
PostPosted: Thu May 08, 2025 10:16 pm    Post subject: Re: late fan shroud removal question Reply with quote
Heart Surgeon scheduled surgery for July. I want to get everything done around here that needs to be done. About a 4% chance of not making it, and 96% chance of improvement. Place your bets.
Only bad thing is afterwards I can't drive for 4 - 6 weeks, can't even pick up one of the dogs for hugs for I think 2 months, and they tell me I will be in the hospital for at least a week. All I can say is if you have a history of back problems, you may want to get tested for the HLA-B27 gene and if it is active, because a life time of the inflammation will destroy your heart very slowly by building calcium up. They'ii tell you that the disease is about one's back, but the more destructive side effect is the calcium the body puts everywhere to wall off an imaginary infection.
George Carlin:
1971 deluxe (sold)
1977 deluxe
busdaddy
busdaddy is offline
PostPosted: Fri May 09, 2025 7:23 am    Post subject: Re: late fan shroud removal question Reply with quote
Shocked Great!, one more thing to worry about next time I have a sore back.
Best wishes for a positive outcome Steve, fingers crossed for you.
As for the possibility of removal with the studs in place?, I'm a chronically lazy guy, if there was any possible way to accomplish the job without removing them I would have found it.
The only way it might happen is with the right combination of loose/worn/rusty heat exchanger shells, or by bending stuff, I doubt either of those apply to your bus.
Слава Україні!
SGKent is offline
PostPosted: Fri May 09, 2025 9:11 am    Post subject: Re: late fan shroud removal question Reply with quote
I even thought about bending an old thin 10 mm at a right angle by heating it, and grinding it to fit in the recess. I am sure it can be pried off but it would take a lot of force and might break something. The heat exchangers were replaced with some new ones BusOk found about 7 or 8 years ago so they are quite robust. I'll just spend 15 minutes and loosen them today.
George Carlin:
1971 deluxe (sold)
1977 deluxe
airschooled
Air-Schooled
PostPosted: Fri May 09, 2025 9:47 am    Post subject: Re: late fan shroud removal question Reply with quote
Good luck with your surgery and recovery.
What job are you removing the fan shroud for? Oil cooler seals are doable with a compliment of 10mm wrenches, phones turned off, light classical or jazz in the background, and a good mood. I don’t pull the shroud for those.. Gallery plugs are less likely….
Luckily you have the later heat exchangers that can be loosened at the U tubes in front. 72-74 folks aren’t so lucky.
Robbie
www.airschooled.com
SGKent is offline
PostPosted: Fri May 09, 2025 9:56 am    Post subject: Re: late fan shroud removal question Reply with quote
Robbie
Thanks Robbie. Leaking gallery plugs. They are weeping enough oil after a 45 minute freeway run to leave a quarter sized puddle both at the front and back of the engine. I already did the ones at the flywheel but the shroud has to come off to do the ones at the fan end. I can't see the one near the oil filter yet. The one between the 3-4 cylinders fortunately is not weeping. For some reason the sealant did not fully cure even though the primer was used. So, the steel plugs are coming out and aluminum ones are going in. Or at least that is the plan with fingers crossed. There is a thread on it that this photo is from. I'll add a photo of the area to that thread once the fan shroud is off. The main reason that I was hoping to avoid loosening the exhaust is that I use some old stock triangular exhaust flange seals that were made really nice, and I don't have too many left. The newer exhaust seals are much thinner and less forgiving although I have plenty of those.
George Carlin:
1971 deluxe (sold)
1977 deluxe
