esde Samba Member
Joined: October 20, 2007 Posts: 6396 Location: central rust belt
Posted: Sat Jun 07, 2025 3:04 pm Post subject: Split and Zwitter seat padding |
Hello,
During the pandemic, I ordered a full set of covers from Marcus Raeke, and am just getting ready to install them onto the restored seat frames..
Marcus did install the front covers onto seat frames, and secured the padding inside the covers so they are filled correctly..
For the rear covers, what padding are people using? I see the stock type from Wolfsburg West, are these good? Are you using burlap over the springs? Did you have to use other padding to help fill the upholstery and what did you use?
My daughter is home from college where she is studying fashion and garment construction, so she is a natural choice to help with this project.. I'm just trying to get as much info as possible going into it.
Lastly, do any of you have web pages or videos bookmarked that might show some of the details of working on these early seats? There are a bunch on the later seats, using TMI covers and foam pads, but they don't really get the details of a properly restored seat.
I'll be sure to document this as we go.. Thanks.
SD _________________ modok wrote:
beetlekey Samba Member
Posted: Mon Jun 09, 2025 7:40 am Post subject: Re: Split and Zwitter seat padding |
Hi,
the rearpaddings fit not well. The quality is getting more and more bad. I use 20 mm plane coconut material and clip it to the frame.
| esde wrote: |
Hello,
SD |
_________________ Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO |
RUNKLE Samba Member
Posted: Mon Jun 09, 2025 7:59 am Post subject: Re: Split and Zwitter seat padding |
Links: 50 Standard Seat Padding • Seat padding for a 53 beetle
| mr magyar wrote: |
Hi,
Here are some photos of the seats from my '49 Standard after the original outer fabric had been removed. There's a layer of the brown sacking like material against the springs, then the grey wirey padding (synthetic horsehair?), another layer of the sacking and finally a layer of the soft, thick grey padding which I think in the UK it's known as shoddy.
I have more photos if you need them for reference.
Cheers,
Andy.
_________________ Type 1
Type 3
1968 Squareback |
Posted: Tue Jun 10, 2025 9:56 pm Post subject: Re: Split and Zwitter seat padding |
You are comparing apples with bananas.
We are talking about coconut ( export ) padding
| RUNKLE wrote: |
| mr magyar wrote: |
Hi,
Cheers,
Andy.
1966 1300
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 1108 Location: Melksham, UK
Posted: Wed Jun 11, 2025 12:08 pm Post subject: Re: Split and Zwitter seat padding |
| esde wrote: |
Hello,
SD |
Quite simply, the primary seat frame and spring covering is Hessian (US = Burlap). Try and get the best quality you can, as this material takes a lot of strain in all directions. https://en.wikipedia.org/wiki/Hessian_fabric
https://burlapfabric.com/burlap-rolls
The padding that sits above this, and under the cover material, is called flock, which is a fibrous material, made from shredded old clothes, hence the many different colours exhibited in the material. In the old days, this basic raw material was supplied by the those in the 'rag and bone ' trade, and was big business: https://en.wikipedia.org/wiki/Rag-and-bone_man
Thus, the material found in old seats generally consists of natural fibres, as man made fibres were less common back in the day, and it is better to replace the material again with natural fibres, as they permit body moisture to escape. As example can be found here: https://www.ebay.co.uk/itm/144163210742?chn=ps&...7ad4ee3295 |
scarabee Samba Member
Joined: May 14, 2021 Posts: 190 Location: South Africa
Posted: Thu Jun 12, 2025 2:56 am Post subject: Re: Split and Zwitter seat padding |
| ^^ Very interesting, Martin. Thanks. |
esde Samba Member
Posted: Thu Jun 12, 2025 4:39 am Post subject: Re: Split and Zwitter seat padding |
This is all very interesting, thank you
I have some burlap to cover the springs, a tighter weave that we use for wrapping root balls. I wonder if it is suitable? And, I did already order the pads from Wolfsburg West. I assume they will be mostly the correct shape and fit, but if not is it possible to add padding to make them fit better? Would you add padding between the cover and coconut pad, or between the springs and coconut pad?
Beetlekey, do you have any details you would share about how you make your pads? I realizer you run a business and don't want to give away your secrets, but any advice and methods you can give is much appreciated. _________________ modok wrote:
pat griffith Samba Member
Posted: Thu Jun 12, 2025 6:39 am Post subject: Re: Split and Zwitter seat padding |
| I recently had my seats redone using WW seat pads. The rear seats came out very nice. I believe some modification were made to make them fit right. The front seats came out ok but there were some issues. The main one being the seat backs that came out a little to thick to me. I wouldn't add any foam to them. On the seat bottoms I would study some of the pictures on Marcus site to see what a correctly done seat looks like. The seam on the seat bottom needs to be pulled down in order to make them look original. I would imagine there is a lot of fitting and refitting when putting the covers on. The original seat pad material on my seats were in bad condition and unusable. If yours are in good shape I would use them and perhaps add some new material to build them up. I have seen plenty of photos on your gallery. No doubt your skill level is up to it. |
RUNKLE Samba Member
Posted: Thu Jun 12, 2025 7:49 am Post subject: Re: Split and Zwitter seat padding |
| beetlekey wrote: |
We are talking about coconut (export ) padding |
The OP had a question regarding placement of burlap.
. _________________ Type 1
Type 3
1968 Squareback |
Posted: Mon Jun 16, 2025 5:01 am Post subject: Re: Split and Zwitter seat padding |
| When I bought my present Kubel 25+ years ago, which I believe found itself in Italy at the end of the war, when I stripped the covered front seats down, what I found was layers of old clothing and hay. Whatever you could get your hands on back in the day! |
