CB Performance 2242 Cam Performance
TheRookie
TheRookie is offline
PostPosted: Sun May 11, 2025 1:39 pm    Post subject: CB Performance 2242 Cam Performance Reply with quote
Hi Guys
Has any one used this cam how does it perform.
Spec are as follows
Adv. Duration 298°
Dur. @ .050" 248°
Lift @ cam .389"
Lift w/1.1:1 Rocker Arms .428"
I'm rebuilding a 1776cc which I bought with this cam
My engine specs
AS41 full flow case
MAHLE 90.5s
CB2242 cam
CB lightweight lifters
Mildly ported 041 heads
36 Dells
mcmscott
mcmscott is offline
PostPosted: Sun May 11, 2025 1:45 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
Good cam, spinoff of the 120
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
TheRookie
PostPosted: Sun May 11, 2025 1:47 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
It should be good on my engine then ??
SGKent Premium Member
SGKent is offline
PostPosted: Sun May 11, 2025 2:20 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
always ask yourself how you plan to use the vehicle when you buy a cam. There is nothing worse than having a race engine in a street car that will be driven easy. Likewise, if someone plans to occasionally go to the drag races, who wants a cam designed to drive around town. 298 degrees is a lot of cam unless one plans to use it.
Here is what Webcam says about their 288/300 split degree camshaft
Designed for large displacement racing engines. Works well in a off-road application. Great torque! Requires Exhaust System, High Compression Piston, Performance Valve Spring Kit, and New lifters required.
Here is what they say about their 290/290 camshaft
Strong mid and upper end performance for mild track engines. Requires Exhaust System, Performance Valve Spring Kit,
so sit down and realistically decide how you want to use this car before you commit to a camshaft change, and you will be much happier with the final result.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
TheRookie
PostPosted: Sun May 11, 2025 9:28 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
Thanks for the advice, I bought the engine with the cam and being in South Africa cams are not easy to come by and if they are they fairly expensive.
It going to be a daily with the weekend warrior race night.
WaterBuggy_24
WaterBuggy_24 is offline
PostPosted: Tue May 13, 2025 9:55 am    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
I have this same cam in my 1915cc and it is made for turbocharged engines although I don't have a turbo on mine yet. There is quite a bit of overlap with the valves I've been told this is good for turbos.
One day, I may learn.
Probably not today though.
modok
modok is offline
PostPosted: Tue May 13, 2025 5:09 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
It's a good cam for what you want to do.
Usually 9-1 compression is recommended.
Your heads could be better, but the cam is ok
TheRookie
PostPosted: Sun May 18, 2025 11:22 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
I CC'd the heads and they are sitting around 50cc and I'm hoping for a 1.4mm deck height to at least get me to 8.5:1 compression I might have to flycut the heads if we don't get that comp ratio
Rob Combs
Rob Combs is offline
PostPosted: Mon May 19, 2025 7:11 am    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
Since you already have it apart for rebuild and cam install would it not make more sense to deck the case or trim the cylinders to get the deck height closer to 1mm? That’d put you at 8.9 in and by itself. Then you could take a less aggressive cut on your heads to bump it to 9 if that .1 added is crucial enough for your build.
TheRookie
PostPosted: Fri Jun 13, 2025 1:25 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
It's easier to trim the cylinders which is what I will do if in need
TheRookie
PostPosted: Fri Jun 13, 2025 1:28 pm    Post subject: Re: CB Performance 2242 Cam Performance Reply with quote
