Peter T. Samba Member
Joined: October 09, 2006 Posts: 267 Location: Long Island, New York
Posted: Mon May 12, 2025 9:34 am Post subject: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
Im trying to figure out the Mystery Cause of Misfire codes 0300,0303,0305,0343.When I start my 2003 vr6 T4 these codes come on usually when I first started it in the morning intermittently. Then they went away for a while. I noticed that the POV had changed out the plugs and coils 3&5 at some point.
I had the trans and timing chain done 7000 miles ago by a very reputable shop that does T4's.
Every once in a while the same codes would come back and this spring it became much more frequent.
I replaced all the plugs with Bosch made in Germany, all coils (Bremi) and the camshaft position sensor.(Bremi)
Im still getting the codes....
It still is an intermittent issue because my local shop is having a hard time finding the root cause...
Any Thoughts?? |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 469 Location: Asheville, North Carolina
Posted: Mon May 12, 2025 7:02 pm Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
Check fuel pressure and if you have fuel trim data see if the fuel trim is correcting towards rich. Possibly a weak or failing fuel pump.
You've eliminated the ignition as the problem. _________________ If it ain't broke, don't fix it! |
Posted: Fri May 16, 2025 8:10 am Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
EuroTec wrote: |
You've eliminated the ignition as the problem. |
If its a weak fuel pump than why would I keep getting a code for cylinders 3&5 only? wouldn't I get codes for all the cylinders?....Could it be injectors or the rail? |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23616 Location: NYC/Upstate/ROW
Posted: Fri May 16, 2025 10:18 am Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
Are you sending misfires or is it a silky smooth VR6 idle like it should be?
You could have injector or wiring trouble , check for critter damage
Iโm mid island near Port Jeff if you want to come by sometime _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Fri May 16, 2025 8:39 pm Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
Abscate wrote: |
Iโm mid island near Port Jeff if you want to come by sometime |
Thanks for the invite, I just might stop over! It has a rough idle for the first 10 minutes and then it clears up.....sometimes about 10-20 minutes of driving it will buck a little and then clears up. |
Posted: Sat May 17, 2025 1:17 am Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
Peter T. wrote: |
Abscate wrote: |
Iโll pm my contact info. Might be a bad week this week as Iโm UTC +530
SambaBurnsRed Samba Member
Joined: February 07, 2025 Posts: 43 Location: object:1698
Posted: Sat May 17, 2025 12:10 pm Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
On start-up the engine runs "open loop" so combustion mix is determined by
Mass Air
Temperature >Injector volume
After it warms up the O2 sensor trim kicks-in and that will adjust fuel to actual combustion results.
Could check the mass air is in spec, and the O2 trim readings are correct.
High miles, old, leaky injectors spill fuel into the combustion chamber, also bleeds fuel pressure instead off keeping the system inflated (like a bike tire). Another possible is head gasket and coolant in there, but you'd have coolant loss over time. ECU's aren't that black and white. They report what they can, being a clue sometimes to an issue. |
Posted: Sat May 17, 2025 4:21 pm Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
UPDATE!
After running it for a while the 0303 & 0305 are finally gone but 0343 still comes on intermittently at different times.....I had the timing chain done 5000 miles ago but the 0343 just started coming on 2000 miles ago..... |
Posted: Wed May 28, 2025 7:41 pm Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
Latest Update: After replacing all plugs and coils and Cam position sensor (all OEM German) All codes are gone but the 0343 code became 0341. I took it to a German car shop that is very knowledgeable in Eurovans (owner drives one daily) and he determined that its the cam timing actuators. He didn't have time to dig into so I got it home (drove great even though the code kept popping on) I flushed the motor with Liquid Molly and now code doesn't come on until I start it. It will drive without the code coming on, only when I start it.......any thoughts?......gummed up actuators? |
Posted: Thu May 29, 2025 10:29 am Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
How is your battery, battery connections and grounds? You might try a lithium booster on starting, as a test.
Marginal devices do strange things on low voltage (like starting). My Range Rover threw misfire codes below -2 DegC. I went to a Lithium battery (AntiGravity), which corrected the problem. Lithium power is amazing. Range Rovers devour current & batteries (short life) so the LiON provides solid power and voltage |
Posted: Sun Jun 01, 2025 4:32 pm Post subject: Re: Mystery Cause of intermittent Misfire codes 0300,0303,0305,0343 |
SambaBurnsRed wrote: |
I checked the battery which checks out good when I put the load tester on it. I scrubbed the terminals and all the cables attached to the battery too. It still threw the 0341 when I started.
The strange thing about it is as soon as I clear the code it comes back as โpendingโ but doesnโt get thrown until I have to start it again. |
