Auto Transmission Oil Pan Bolt Replacement
northwoodssurvival@gmail.
northwoodssurvival@gmail. is offline
PostPosted: Mon May 12, 2025 1:48 pm    Post subject: Auto Transmission Oil Pan Bolt Replacement Reply with quote
Hi all
I was about to do an auto transmission filter change on my 91 Vanagon, and as luck would have it I broke a transmission oil pan bolt off and need to extract it and replace it. Probably replace them all. The other three bolts are still in the housing and soaking in penetrating oil for the night.
Can anyone help me out with the thread pattern that I need? M 1x6x13mm? I can't seem to find any info on it. Id like to source bolts locally.
In advance, Thanks!
JB
91 Vanagon
2.1l Automatic
125,000 miles
1988M5
1988M5 is offline
PostPosted: Mon May 12, 2025 2:02 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
From memory they are the super common M8-1.25 bolts (8mm diameter, 1.25mm distance between threads). extracting another bolt without breaking would get you the length. You mentioned 13mm in your guess!?? With respect you may want to consider having a shop do the tranny service and get the broken bolt out.
BK
1991 tin top GL
Some BMWs.
PostPosted: Mon May 12, 2025 2:09 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
BK
Thanks. I meant 13mm socket.
I think all of the bolts were over torqued or have never been removed. either way once the other 3 are out hopefully my extraction tool should get the broken one out.
JB
91 Vanagon
2.1l Automatic
125,000 miles
jlrftype7
jlrftype7 is offline
PostPosted: Mon May 12, 2025 2:35 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
Definitely 8mm bolts. Not that long either. 16mm to 20mm would be my guess. with being away from our VW and spare transmissions to pull and check for you.
I can check once I get home. Someone else might chime in with the info from Ekat or similar.
‘84 Tin Top - Hilga....Auto
MarkWard
MarkWard is offline
PostPosted: Mon May 12, 2025 3:59 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
As long as it wasn’t cross threaded, it will likely back out easily. Start with a hammer and a center punch, hitting near the outside edge and walking it out.
If that doesn’t work, a left hand drill and reversed drill will often grab it and walk it out. You really need to drill it centered. Just in case someone else ends up saving you.
Often if you have access to a welder, you can weld a nut to the broken bolt and back out.
Lots of you tube videos on how to deal with broken bolts and studs. I’d start there.
PostPosted: Mon May 12, 2025 4:01 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
Thanks!
91 Vanagon
2.1l Automatic
125,000 miles
PostPosted: Mon May 12, 2025 4:03 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
Thanks Mark
Im going to get after it tomorrow.
Wish me luck!
JB
91 Vanagon
2.1l Automatic
125,000 miles
wesitarz
wesitarz is offline
PostPosted: Mon May 12, 2025 4:44 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
Same. I broke one off. Likely over torqued by the trans shop when they rebuilt it. I drilled it through and replaced it with a bolt and nut with no problem.
kamzcab86
kamzcab86 is offline
PostPosted: Mon May 12, 2025 9:57 pm    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
M8x20
https://www.heritagepartscentre.com/us/n01024016-hexagonal-bolt-m8x20.html
Just did that job myself... only problem I had was with the frackin' pan gasket.
~Kamz Anxious
2016 Golf GTI S
MarkWard
MarkWard is offline
PostPosted: Tue May 13, 2025 5:50 am    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
I’d try every method to remove the broken bolt, before drilling it through and through bolting it with a nut and bolt. Maybe in an emergency, but It would just be a better repair if you can reuse the case threads. Just my opinion.
PostPosted: Tue May 13, 2025 9:40 am    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
For sure. It does work, but I'm going to try a bolt extraction tool and some heat. I'll drill thru as a Hail Mary if need be.
Thanks for the input! much appreciated
91 Vanagon
2.1l Automatic
125,000 miles
PostPosted: Tue May 13, 2025 9:42 am    Post subject: Re: Auto Transmission Oil Pan Bolt Replacement Reply with quote
That's the plan Mark. The Hail Mary plan is a drill thru. I have done it on an old Chev truck of mine and had no issue.
91 Vanagon
2.1l Automatic
125,000 miles
