Holes in fuel tank compartment
Adriou
Adriou is offline
PostPosted: Tue May 13, 2025 2:10 pm    Post subject: Holes in fuel tank compartment Reply with quote
What are these three holes for?
Should I plug these with a grommet before putting the tank back ?
These were empty prior, but my bus misses half of its grommets...
busdaddy
busdaddy is offline
PostPosted: Tue May 13, 2025 3:27 pm    Post subject: Re: Holes in fuel tank compartment Reply with quote
Since you are keeping the year of your bus a secret I can't say for sure, but later models had clips for fuel lines there.
Слава Україні!
Adriou
Adriou is offline
PostPosted: Tue May 13, 2025 4:00 pm    Post subject: Re: Holes in fuel tank compartment Reply with quote
Thanks for the swift reply!
1974 is the DOB of my beauty !
SGKent Premium Member
SGKent is offline
PostPosted: Tue May 13, 2025 4:27 pm    Post subject: Re: Holes in fuel tank compartment Reply with quote
what Mark said, nylon clips that pop in from the bottom which hold the fuel lines up. I think they can only be found used. GM style snap clamps that hold plastic wire sheathing will work in them too,
VDubTech
VDubTech is offline
PostPosted: Wed May 14, 2025 6:20 am    Post subject: Re: Holes in fuel tank compartment Reply with quote
No they didn't. No Bus has clips for fuel lines that run along the underside of the floor of the fuel tank compartment. On late FI Buses the sender line exits the tank towards the front of the Bus and goes to a metal pipe that runs along the panel between the lower wheel wells(which does have clips to secure it) and the return line goes towards the rear of the Bus and connects to the FPR. Nothing attaches to the underside of the floor of the fuel tank compartment.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
mikedjames
mikedjames is offline
PostPosted: Fri May 16, 2025 9:50 am    Post subject: Re: Holes in fuel tank compartment Reply with quote
Strange, my 1973 built bus has clips.
Ancient vehicles and vessels
busdaddy
busdaddy is offline
PostPosted: Fri May 16, 2025 10:47 am    Post subject: Re: Holes in fuel tank compartment Reply with quote
They all do, except the ones delivered to Syracuse apparently. Confused
https://www.thesamba.com/vw/forum/viewtopic.php?t=550725&highlight=fuel+clips
Слава Україні!
SGKent is offline
PostPosted: Fri May 16, 2025 11:07 am    Post subject: Re: Holes in fuel tank compartment Reply with quote
mine have them, and in 1977 I think the hoses were rubber and not steel. Maybe 1978 and 1979 have the steel lines. I seem to recall reading on that. There are also wires that connect thru one or more hangers on my 1977. Don't recall what the 1971 was like under there.
busdaddy
busdaddy is offline
PostPosted: Fri May 16, 2025 12:41 pm    Post subject: Re: Holes in fuel tank compartment Reply with quote
SGKent wrote:
..... Don't recall what the 1971 was like under there.
Bendy steel tabs, I think the 72 did as well.
Слава Україні!
