AN fittings for fuel hoses
MTT3107
MTT3107 is offline
PostPosted: Tue May 13, 2025 5:10 pm    Post subject: AN fittings for fuel hoses Reply with quote
So, I want to convert my fuel hoses to AN fittings.
I have dual EMPI HPMX 40’s on my bug.
I think I would need AN6 fittings, but want to make sure before ordering
Dougy Dee
Dougy Dee is offline
PostPosted: Tue May 13, 2025 5:14 pm    Post subject: Re: AN fittings for fuel hoses Reply with quote
AN6 will be good. -4 are a pain to assemble.
txoval
txoval is offline
PostPosted: Tue May 13, 2025 5:52 pm    Post subject: Re: AN fittings for fuel hoses Reply with quote
Agree, ran -6 from tank to both carbs.
Rob Combs
Rob Combs is offline
PostPosted: Tue May 13, 2025 10:11 pm    Post subject: Re: AN fittings for fuel hoses Reply with quote
I used AN4s. Gates vapor guard fuel hose. Get the end of the hose real warm. Push the fitting end on the hose quickly using a towel to protect yourself from the heat.
I used boiling water. Not difficult at all.
Never have fuel volume trouble either.
FWIW
cjsuner
cjsuner is offline
PostPosted: Wed May 14, 2025 10:35 am    Post subject: Re: AN fittings for fuel hoses Reply with quote
I'm currently in the process of doing it on mine too, I used -6.
What I am mainly concerned about with mine is the fittings on the carbs, as I don't have threaded fuel inlets, they are press in brass fittings.
(Ignore the leak... has be dealt with)
71 Super Convertible (Orange)
74 Standard Beetle (Light Blue)
sidemarkers
sidemarkers is offline
PostPosted: Wed May 14, 2025 11:35 am    Post subject: Re: AN fittings for fuel hoses Reply with quote
Recently bought a pair of quality stainless hose shears. Wish I would have done that 30 years ago.
Augie
Augie is offline
PostPosted: Wed May 14, 2025 7:03 pm    Post subject: Re: AN fittings for fuel hoses Reply with quote
I have -4, got line and fittings from Earls.
slalombuggy
slalombuggy is offline
PostPosted: Thu May 15, 2025 5:10 am    Post subject: Re: AN fittings for fuel hoses Reply with quote
As long as uoi use a qualitÿ fitting and insrall it well, tgere is no problems using a compressuon fitting for your AN adapter. I had to use them a couple of times and have nevrr had a leak.
