Derickpete Samba Member
Joined: October 01, 2013 Posts: 22 Location: Gardnerville Nv
Posted: Sat May 17, 2025 8:29 am Post subject: Derlin Bushings |
I just installed a Warrior beam, stock width. Using the stock spring packs that were in the old beam. When I installed the arms, the top spring is perfectly located in the beam but there is a 1/8” gap between the arm and the derlin bushings on both sides. The arms will not move inwards because the lock down bolt falls perfectly into the indentations on the springs. The gap between the the upper arm and the lower arm is 5mm and the knuckles are tight on both sides. My question is should I worry about this little gap? Is the normal for a aftermarket beam? Everything is tight and smooth throughout the suspension cycle. Thoughts? |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4607 Location: Fair Oaks/Orangevale, CA
Posted: Sun May 18, 2025 7:32 am Post subject: Re: Derlin Bushings |
In the past there were some of the aftermarket beams that used a Oring to seal end of beam to the trailing arm.
You could add Oring if you want to fill the gap.
There are several different types of Delrin beam bushings, SACO white ones, Blue ones, and the Grey ones, which ones are you using? _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Sun May 18, 2025 4:54 pm Post subject: Re: Derlin Bushings |
They are red. I believe they are EMPI bushings for the Warrior beam. |
Posted: Sun May 18, 2025 6:55 pm Post subject: Re: Derlin Bushings |
The red trailing arm bushings are made from Urethane, They are not Delrin.
The grease that you want to use to make them last and not break down is
Super Lube Synthetic Grease. It has PTFE (Teflon) in it. Regular wheel bearing/chassis lube grease causes the Urethane to break down.
Super Lube can be found in both small and large size for different grease guns, also available in 3 oz tubes. _________________ Joseph
Elrod Motorsports
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3544 Location: West Coast (Michigan's)
Posted: Mon May 19, 2025 12:56 pm Post subject: Re: Derlin Bushings |
To add to that, Super Lube is a silicone based grease which I understand to be the important factor for PU. There are not a lot of options to use anyway if you just search for silicone grease that comes in a grease gunable tube.
The oring idea to make up the gap is a good idea. I think I would rather have your problem than the opposite and not be able to reach the dimples with the grub screws. That would be my luck for sure!
But when you use these bushings you need to be prepared to modify them all to a certain degree to get them to fit right. I think the actual delrin type require a special sized reamer to get them to work correctly which is why I didn't go with those lol. I think they are better though. PU is pretty low maintenance but Delrin , IINM, is a plastic that's self lubricating. _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
Crogg Samba Member
Joined: September 30, 2023 Posts: 92 Location: Oregon
Posted: Fri May 23, 2025 10:49 am Post subject: Re: Derlin Bushings |
I have the cheap red delrins myself. Definitely stay away from urathane. adding zert fittings to your beam would be smart? I am running the same setup on one of my bugs. My beam is 10 years old... quality is not what it used to be. I would cover the gap with some leather to keep dirt out.
As for reaming delrins... you dont need a special tool. I posted a way to get it done about a year ago. |
