Kevin1957 Samba Member
Posted: Sat May 17, 2025 11:58 am Post subject: New wiring harness: reverse light installation on transmission |
Installing a new wiring harness. It's a tight fit to install the reverse light wires on the transmission nosecone and I haven't been able to do it. Is there a method to installing these wires with the transmission still in the car? Thanks. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79240 Location: Sneaking up behind you
Posted: Sat May 17, 2025 12:01 pm Post subject: Re: New wiring harness: reverse light installation on transmission |
Some of the aftermarket switches are longer making it a very tight fit.
Try needle nose pliers to slide the wires on. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sat May 17, 2025 12:03 pm Post subject: Re: New wiring harness: reverse light installation on transmission |
Tried that but no luck. Will try again. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6035 Location: 37.5N 77.1W
Posted: Sat May 17, 2025 8:17 pm Post subject: Re: New wiring harness: reverse light installation on transmission |
Quote: |
installing these wires |
'They' make 90 degree quick disconnect connectors
https://www.amazon.com/dp/B09T3DVBWB/ref=twister_B09T3D3VRN?_encoding=UTF8&psc=1 _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Sun May 18, 2025 5:05 am Post subject: Re: New wiring harness: reverse light installation on transmission |
Great suggestion. I just ordered some. Thanks. |
