Distributor Short
1105 is offline
PostPosted: Sat May 17, 2025 2:44 pm    Post subject: Distributor Short Reply with quote
Returned home last night from a 5000 mile trip to the East Coast and back home in a 1959 Beetle. Went out this am to check timing and I noticed there is a short as the timing light has a dull glow when I touch it to the block. I noticed points plate gave me a shock. It is an VJR 4BR8 mechanical advance distributor on a Stale Air 40 HP 1385 with 83mm pistons. Anyone have any Ideas what to check?
Thanks,
1105
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat May 17, 2025 3:28 pm    Post subject: Re: Distributor Short Reply with quote
Make sure the clip on the bolt is not touching the breaker plate.
If it is then the engine won't run.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
1105
1105 is offline
PostPosted: Sun May 18, 2025 8:14 am    Post subject: Re: Distributor Short Reply with quote
Thanks, I will check it.
1105
1105
1105 is offline
PostPosted: Mon May 19, 2025 9:00 am    Post subject: Re: Distributor Short Reply with quote
I took the nuts off of the bolt that hold the clip and moved and put everything back together and all was ok.
Thanks so much.
1105
