ohiovw Samba Member
Posted: Sun May 18, 2025 9:52 am Post subject: installing seat stand rubber mats |
Before I let my frustration meter climb too high are there any tips for getting the rubber strip in the trim in the seat stand and keeping it there during installation. I spent 5 minutes poking it in, then seeing it pop out a second later in areas. I figured someone may have some wisdom to share.
_________________ -Will
1969 bay window
build thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=802451&highlight= |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1145 Location: SW Colorado
Posted: Sun May 18, 2025 10:54 am Post subject: Re: installing seat stand rubber mats |
I have found that the combination of mis- molded repro rubber and the usually banged around edges of what used to hold the trim edges--causes this iissue with many types of seals in many applications. What I do is get the qtips and black weatherstripping adhesive out and sparingly apply dabs of adhesive to unseen areas, et it dry about 8-10 minutes, then start pushing everything in. Do small sections at a time and put glue on both surfaces opposite itself, masking tape to hold it down till dry. I just installed hood seal on my 65 bug yesterday and believe me-- there wasn't any way that piece was gonna stay on by itself. Good lick _________________ "A life of peace and happiness depends on your own gratefulness" |
timvw7476 Samba Member
Posted: Sun May 18, 2025 4:22 pm Post subject: Re: installing seat stand rubber mats |
a heat gun from HF may help. Use low-temp setting of course. (mine has two *
& high is too much! Also putting the mat in direct sun can do a lot. It's black. Should soak up heat & be more docile. |
Greg Schoolbus Samba Member
Joined: January 28, 2024 Posts: 37 Location: Central California
Posted: Sun May 18, 2025 10:16 pm Post subject: Re: installing seat stand rubber mats |
This might be against the rules, but tapping the metal with a block and a medium hammer to close up the slot just a tad worked for me. _________________ 1974 Transporter
Zen and the Art of Motorcycle Maintenance: "The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." |
ohiovw Samba Member
Posted: Sun May 18, 2025 10:52 pm Post subject: Re: installing seat stand rubber mats |
Greg Schoolbus wrote: |
This might be against the rules, but tapping the metal with a block and a medium hammer to close up the slot just a tad worked for me. |
I was kind of wondering it that was by design myself. _________________ -Will
1969 bay window
build thread:
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42103 Location: at the beach
Posted: Sun May 18, 2025 11:19 pm Post subject: Re: installing seat stand rubber mats |
as I recall, the originals were glued on with something like a 3m spray and the edges went under the crimps. The crimps get opened up a little, the new mat edges slide in and then the metal gets gently tapped down like the last poster suggested. The tails slide under the floor mats front, maybe the walk thru and the back. The rot out after about 7 - 10 years if exposed to sun and ozone. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
ohiovw Samba Member
Posted: Mon May 19, 2025 11:42 am Post subject: Re: installing seat stand rubber mats |
SGKent wrote: |
as I recall, the originals were glued on with something like a 3m spray and the edges went under the crimps. The crimps get opened up a little, the new mat edges slide in and then the metal gets gently tapped down like the last poster suggested. The tails slide under the floor mats front, maybe the walk thru and the back. The rot out after about 7 - 10 years if exposed to sun and ozone. |
Yes, that makes sense. After sweeping out all the horse hair residue(that really is horse hair?), I could see old glue residue on the seat stand. _________________ -Will
1969 bay window
build thread:
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13413 Location: West Coast, USA
Posted: Mon May 19, 2025 12:01 pm Post subject: Re: installing seat stand rubber mats |
ohiovw wrote: |
I was kind of wondering it that was by design myself. |
Against the rules? Whose rules? It’s your car, hammer away and enjoy seat mats that never migrate.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Joined: January 01, 2007 Posts: 17776 Location: sticksville, ct.
Posted: Mon May 19, 2025 6:15 pm Post subject: Re: installing seat stand rubber mats |
OE mats were glued and had pie shaped reliefs cut as needed on the flap so they'd sit in the channel nicely. and yes, they were shoved in a whacked shut with a mallet _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
