Stock × 1in rear trailing arm alignment issues.
WaterBuggy_24
WaterBuggy_24 is offline
PostPosted: Sun May 18, 2025 1:02 pm    Post subject: Stock × 1in rear trailing arm alignment issues. Reply with quote
I know there have been threads about aftermarket boxed style trailing arms having alignment problems. The same tow in or camber issues. Has anyone come to any conclusions to the issue?
One day, I may learn.
Probably not today though.
Wulfthang
Wulfthang is offline
PostPosted: Sun May 18, 2025 7:05 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
I bought a brand new set of stock plus one inch length arms and installed them. It had so much positive camber, I could feel it wiggling on the road. I tried everything to lessen it. Six foot long pry bars, shims, elongating the holes, etc. Nothing worked well enough to make me happy.
I am now getting ready to swap them over upside down from what they are now. They had no markings on them to indicate up or down so I took some opinions from here and made a best guess. Hopefully, this fixes it.
WaterBuggy_24
PostPosted: Sun May 18, 2025 10:32 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
When I first installed mine I had that very problem. I had cut my shock mounts off that I welded on them. They were not marked, but I was told that the side that looked double plated was the top. That was not the case though . I flipped them over and they are better, but still not right. It almost looks to me as if the bearing carrier is welded wrong like the jig the built it with was off. My rear tires tow in by almost two and a half inches and if I elongate the holes on the spring plate mount, it will make the flat plate point outward and not bolt up without bending it. Those arm are to dang expensive really to have to do any experimental fab work to.
Wulfthang
PostPosted: Mon May 19, 2025 10:01 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Would it be possible to shim the trailing arm pivots to cause the trailing arms to po0pint more outwards?
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Mon May 19, 2025 12:44 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Maybe ten years ago I bought a set from Avery's Air Cooled. At the time they were the best you could get, american made as opposed to the chinesium ones just about everybody was buying. I slurged on those big time. I put them on Orange which had previously been a swing axle rail. The IRS I got for Orange had been welded to a half inch plate and used in a trike conversion. (My luck finding janky parts is second to none). Between welding in a whole new torsion, using a completely new suspension I had never worked with before, attempting to use airbags, and swapping in a 094 trans mated to a GM Quad4 water pumper there was a lot to keep track of. Years later I would finally realise that despite spending the money to avoid the camber issue I had it anyway.
I don't know if all that heat that had been put into that torsion to weld that plate onto it had thown everything off or I possibly clocked the torsion somehow, or it has been the A-arms all along.
Long story short, despite having welded brackets for shocks to the "tops" the only thing I can think to do is swap sides which will put the mounts on the bottom OR weld in new inner pivot pockets. Both more work than I want right now. So I deal.
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
ORANGECRUSHer
PostPosted: Mon May 19, 2025 12:49 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Mine were 2x2's but same problem I guess.
You kinda see it in this pic. And both sides are not the same which makes it that much more fun!
Brian H.
WaterBuggy_24
PostPosted: Sun May 25, 2025 5:33 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
I was in the garage looking at my rear arms and I definitely believe now the axles are not passing through the arm parallel with the rest of the axle . If I were to shim the pivot point enough to change the tow/camber, it would contact solidly against the engine horn.
What really sucks is that my trailing arms have a powder coating that isn't very old at all. So with that I will have to deal with it also or spend money on new powder coating if I re-weld. Sad
Bad Frog
Bad Frog is offline
PostPosted: Sun May 25, 2025 10:59 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
So...this thread is timely in that I am looking to buy a set of rear stock x 1in trailing arms. It seems that there is only Latest Rage brand out there which I believe are made in Asia somewhere. Does anybody make these domestically and without quality control issues? I am willing to pay more to get something quality that doesn't require the drama you guys are going through. My life has too much drama as it is. Any guidance would be greatly appreciated.
BF
Schepp
Schepp is offline
PostPosted: Mon May 26, 2025 10:43 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
As far as coatings go I’m over powder coating anything that will possibly be modified later. If you use Steel-it you can weld through the coating then re-spray.
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Mon May 26, 2025 12:29 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Stock arms have gotten me many thousands of miles off road and tire wear is perfect. I bought my baja with 1980's dead even straight across bald tires @ that moment I knew it was a good straight car. I will never buy that aftermarket junk. It wont make your VW a SXS killer.
When I buy used cars I only buy ones with old tires two reasons you can talk the price way down and you know if it has suspension/ frame issues in the first 20secs
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
Wulfthang
PostPosted: Mon May 26, 2025 7:02 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Yeah yeah but there are many valid reasons to increase the length and/or width of the arms.
Schepp
Schepp is offline
PostPosted: Tue May 27, 2025 7:29 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
I really only see a benefit to increasing wheel travel and track width/length beyond stock components is if you're running the car at high speeds off road. Keeping a stock wheelbase allows you to run tighter trails and keeps the car more nimble.
you don't need as big of a space to work on it either.
I see no reason for big tires, expensive transaxles and suspension if you're not racing or running in an open desert environment at speed.
Smaller tires will save your tranny and wont make your engine work harder than it needs to.
I'm very happy with my choice of 225/75's and keeping it stock.
Wulfthang
PostPosted: Tue May 27, 2025 7:52 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
I run a Ford V6 engine and it's significantly heavier than the stock 4 banger. The rear end sagged some sitting there but bottomed out bad on the trails so I went with a heavier torsion. That caused it's own problems. It stopped the bottoming out but it was to stiff. Softening it up by one notch made it to loose but adding one inch to the trailing arm for some added leverage was perfect. Soft enough for comfort but stiff enough to not bottom out.
Here in Southern Arizona, we run a lot of Arroyos aka Washes aka dry river beds. Sometimes, the surface is hard with lot's of tiny rocks but other times, it's so soft, you sink up to your ankles when you stand on it. Skinny tires don't do well on that type of surface. Then factor in driving over old mine trailings that will cut your tires. Fat tires running low pressure are best for things like that.
Sometimes, skinny tires are better but not always.
Regarding: "I see no reason for big tires, expensive transaxles and suspension if you're not racing or running in an open desert environment at speed"
It ain't about reasons. It's about WANT!
Schepp
Schepp is offline
PostPosted: Tue May 27, 2025 9:19 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Wulfthang,
One must ask after all you've been through with the V6 swap, was it worth it vs building a bigger air-cooled engine?
After years of reading your posts, it sounds like many of the problems you've faced are self-induced. Stemming from the V6 swap.
I'm not saying that I wont stay air-cooled forever but once you head down that path of swapping engines when do the problems down-stream ever end?
This a major reason I chose to stick air-cooled instead of a modern swap.
It works.
For those who are sticking with air-cooled, is all the added hassle worth the extra inch?
If you're racing, sure because it gives you an edge.
For the average human, probably not.
ORANGECRUSHer
PostPosted: Tue May 27, 2025 10:42 am    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Yes. I'm very proud of the powder coating I've done. I even built a big oven from scratch that I could bake large parts in. I've since sold that. But unfortunately, all that powdercoating has kept me from wanting to modify things as well.
I used to have airbags attached to my arms and the mounting plates are still there because I don't want to disturb the coating. I'm not sure I really care anymore though. I have some new calipers I need to fab mounts for and I'm not gonna care about the coating while I do it. Things don't last long enough to worry about cosmetic crap on a buggy.
I'm friends with a group on facebook called Backyard Buggies. I've went out with them a couple times. They have more fun than I do that's for sure. I'm in the garage fussing about my wiring not being labeled right and they're out actually driving buggies litereally held together with duct tape, zipstrips and cheetos bags.
Sometimes you have to evaluate just how big of a deal something is and wether it's worth keeping you from having fun is worth it.
Brian H.
Wulfthang
PostPosted: Tue May 27, 2025 7:47 pm    Post subject: Re: Stock × 1in rear trailing arm alignment issues. Reply with quote
Schepp wrote:
Wulfthang,
It works.
Air cooled has it's place but I wanted more power than can be reliably squeezed out of an air cooled engine. If I look back on all of the trials and tribulations that I've gone thru with it and balance that against the amount of fun that it gives me, Oh Hell yes, I'd do it all over again.
In all honesty, a lot of the issues on my build, was the customization required for the engine. It's a Ford V6, a European metric Cologne 2.8 naturally aspirated. All of the linkages, water fittings, headers, etc. had to be custom machined and/or built. There's easier engines to use but this is what I had.
I had a fairly hot VW powered Baja back in the day. There is just no comparison between it and my V6 powered Rat Rod Trail Rail. The sound, the smooth power surge taking off, etc. all combine to make it the most fun I can have with my clothes on.
It's legal for street use and is a daily driver except for the current trailing arm issues. The engine is reliable, runs within specs on temps and pressures and supplies more horsepower than I need but I sure do enjoy using it!
