Fuel quantity sender
MTT3107
MTT3107 is offline
PostPosted: Mon May 19, 2025 3:55 pm    Post subject: Fuel quantity sender Reply with quote
Is there a "correct" way to install it ?
The arm to the left, right, fwd, backward ?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon May 19, 2025 4:03 pm    Post subject: Re: Fuel quantity sender Reply with quote
There's 5 screws, only 1 way makes sense.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bsairhead
bsairhead is online now
PostPosted: Mon May 19, 2025 5:04 pm    Post subject: Re: Fuel quantity sender Reply with quote
The video I just watched sure looks like it goes left. Drivers side on a left hand drive vehicle. Google is your friend.
MTT3107
MTT3107 is offline
PostPosted: Mon May 19, 2025 5:07 pm    Post subject: Re: Fuel quantity sender Reply with quote
Which way "makes sense" ?
With 5 screws, there 4 different possibilities....
bsairhead
PostPosted: Mon May 19, 2025 5:10 pm    Post subject: Re: Fuel quantity sender Reply with quote
It sure can't go forward.
Mr. 010
Glenn is offline
PostPosted: Mon May 19, 2025 5:12 pm    Post subject: Re: Fuel quantity sender Reply with quote
The float doesn't fit some of the ways.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Mon May 19, 2025 7:55 pm    Post subject: Re: Fuel quantity sender Reply with quote
There's only one way the holes on the sender will align with the holes on the tank.
Tom
"Following distance is proportional to IQ."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
"Research is what I'm doing when I don't know what I'm doing." Wernher von Braun
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
baldessariclan
baldessariclan is offline
PostPosted: Tue May 20, 2025 6:00 am    Post subject: Re: Fuel quantity sender Reply with quote
Yeah, the 5 screw holes aren't spaced evenly -- ensures that the sender is always aligned in the correct direction on the tank.
