jforero Samba Member
Joined: September 24, 2009 Posts: 2 Location: Houston
Posted: Sat Oct 06, 2012 4:25 pm Post subject: 1991 vanagon headlight switch melted. |
Folks the headlight switch in my 1991 vanagon overheated and melted. The part number on the switch is 251-941-531Q. I understand that number has been superseded by 251-941-531T but VW no longer supplies that switch. Does anyone have a swith that I can buy or does anyone know if I can use a swith from an earlier model and make it work? |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10916 Location: Western WA
Posted: Sat Oct 06, 2012 5:26 pm Post subject: |
If you use a "headlight relay kit" then any switch will be sufficient. You might check your headlight bulbs, maybe the reason the switch melted is because your van has (some or all 4) higher wattage headlight bulbs.
To run higher wattage bulbs, the "relay kit" is absolutely required. And if you add the relay kit, your next switch can be old, used and will still last forever because all the real power goes thru the relay. _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important.
Corwyn  Samba Member
Joined: December 29, 2009 Posts: 2453 Location: Olympia, Washington
Posted: Sat Oct 06, 2012 5:32 pm Post subject: |
Both GW and VC carry the headlight switch. Yours melted because you are drawing too much current through the switch. Check either of the aforementioned vendors for a high power headlight relay kit. _________________ '90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4634 Location: East Kootenay, British Columbia
Posted: Sat Oct 06, 2012 5:33 pm Post subject: |
http://www.van-cafe.com/home/van/smartlist_585/headlight_switch.html _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10493 Location: Orbiting San Diego
Posted: Sat Oct 06, 2012 8:45 pm Post subject: Re: 1991 vanagon headlight switch melted. |
The dash wiring harness is different to support the new type switch. If you substitute the older type switch into the newer dash harness you will be bypassing the protection fuse for the dash lighting. That is not a good idea.
You could splice a fuse inline with the gray/blue wire leaving the switch to restore fuse protection.
Mark
| jforero wrote: |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Sun Oct 07, 2012 11:54 am Post subject: |
Frank Condelli sp? fuse relay kit is only $37 from his site, was checking it out last night. _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
susan dolvin Samba Member
Posted: Thu May 22, 2025 11:15 am Post subject: Re: 1991 vanagon headlight switch |
Hi, does anyone know where to get a 1991 headlight switch? It was working but then the tail lights quit. HaVe checked vc and gw both out of stock.
Thank u so much for any clues.
This is for a bus for my grandson.
Susan Dolvin
1966 Dormobile Westy
1988 Riviera weekender
1990 Westy |
zerotofifty Samba Member
