eurojudy Samba Member
Joined: April 16, 2022 Posts: 23 Location: Petaluma, CA
Posted: Wed May 21, 2025 12:06 pm Post subject: PD9300 charger max amps? |
How many amps can a replacement for the Magnatek be? I am looking at the Progressive Dynamics 30 vs 45a versions. |
TheOneTrueQuux Samba Member
Posted: Wed May 21, 2025 12:53 pm Post subject: Re: PD9300 charger max amps? |
eurojudy wrote: |
I replaced mine with a Victron 20A charger, and it's fine. The victron unit very compact, and works really well. |
xEVC Samba Member
Joined: March 23, 2017 Posts: 130 Location: California
Posted: Thu May 22, 2025 9:27 am Post subject: Re: PD9300 charger max amps? |
Depending on your model year, there are either 30 or 40 amp fuses in the circuit going to the house battery. Therefore I would not recommend trying to charge above 30 A. I have a Victron IP 22, 30 amp charger and it works great. _________________ 2000 Eurovan Camper (Winnebago)
Upgraded with 16" wheels |
bigfoot_ev Samba Member
Posted: Fri May 23, 2025 4:54 pm Post subject: Re: PD9300 charger max amps? |
If you're going to replace your MagneTek, which I think most everyone would agree is a good idea, I strongly second (third?) the Victron IP 22. It's a great charger and the control via bluetooth is unmatched in it's price range. A great way to future proof your charging system. |
Posted: Sun Jun 08, 2025 1:04 pm Post subject: Re: PD9300 charger max amps? |
@bigfoot_ev does this charger work with lithium batteries? i may add that down the line. |
dsh1705  Samba Member
Joined: June 11, 2014 Posts: 131 Location: Seattle, WA
Posted: Sun Jun 08, 2025 2:53 pm Post subject: Re: PD9300 charger max amps? |
thanks David! |
Posted: Thu Jun 12, 2025 4:01 pm Post subject: Re: PD9300 charger max amps? |
UPDATE: I found a mobile RV guy who came over just a few days after we connected. I found out he is a recent Ukrainian refugee and could not have been nicer, smarter, friendlier, more well-equipped or patient, letting me hang out with him and ask questions etc. He hadn't worked on a Eurovan before but using the instructions I printed out from xochi.com and 1705.net, and a liberal use of chatgpt (!), he got it done in 4 hours. I ended up using the Victron IP22 and all is well.
