Scott SD Samba Member
Joined: June 22, 2010 Posts: 174 Location: San Diego, CA
Posted: Wed May 21, 2025 4:03 pm Post subject: Fuel Cell/Pump |
Need a sanity check on my plan for fuel plumbing. I have a 22g RCI fuel cell mounted 1/2" over the tunnel, behind the seats in my caged baja. Just finished the tray fab, now moving onto the plumbing. The plan is to run 2 pumps in parallel for redundancy, switch on the dash to run either pump.
Top of the fuel cell
-10 AN fuel pick-up, reduce to -8 AN
½” hardline to the side of the fuel cell
Side of the fuel cell
100 micron filter & shut-off valve, reduce to -6 AN
Under the fuel cell (stock battery location)
Tee going to a (2) separate Carter rotary pumps, each with a 10 micron filter, check valve, then to another tee, then to a regulator mounted to the firewall.
My concern is that because it is a circle track fuel cell and has the pick-up top mounted, the pumps will not be able to adequately pull from the top of the tank and back down. I know most pumps are pushers, and only a few are good suckers. What do guys have for a fuel pump that run circle track fuel cells? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11195 Location: Oregon
Posted: Wed May 21, 2025 4:26 pm Post subject: Re: Fuel Cell/Pump |
IMO, you should be ok with the rotary pump setup as described.
I used a Carter rotary pump to empty my Eurovan fuel tank last week to facilitate a fuel pump change. I pumped out 11 gallons without any issues.
My understanding is, that the rotary pumps cannot lift more than two feet. If you are under that measurement, you should be ok. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 808 Location: Reno NV
Posted: Thu May 22, 2025 8:48 am Post subject: Re: Fuel Cell/Pump |
the pumps are below the tank, and will syphon to the pumps after the line fills. I would put a shutoff before the pumps on top of the tank. otherwise if you spring a leek you have no way to stop it.
Last edited by halfassleatherworks on Thu May 22, 2025 4:45 pm; edited 1 time in total |
Posted: Thu May 22, 2025 4:16 pm Post subject: Re: Fuel Cell/Pump |
Thanks guys. Just needed some confidence before I start ordering fittings. I will post pics when I am done. |
