Steering wheel coupler bending when tightened down
flatfour
flatfour is offline
PostPosted: Wed May 21, 2025 7:20 pm    Post subject: Steering wheel coupler bending when tightened down Reply with quote
On my '74 ghia I replaced my steering box with a genuine VW rebuilt box, and after I replacing it the steering coupler is bending some when tightened down as you can see in the pics. I'm not sure if this is a really an issue or not but is there a fix for this? It seems to work fine just not sure if there is a fix for this or if it even needs fixed?
[/img]
'68 Bug
'74 Ghia
bnam
bnam is offline
PostPosted: Thu May 22, 2025 12:36 am    Post subject: Re: Steering wheel coupler bending when tightened down Reply with quote
Loosen the clamp bolt that holds the flange to the steering column. This should allow the flange to slide a bit forward and eliminate the bend. Then retighten the clamp.
Byas
Click to view image
1952 Citroen TA 11BL
flatfour
flatfour is offline
PostPosted: Thu May 22, 2025 8:40 am    Post subject: Re: Steering wheel coupler bending when tightened down Reply with quote
I was able to loosen the clamp and move the flange some. It is definitely better but not all the way flush but much better than before.
'68 Bug
'74 Ghia
runamoc Premium Member
runamoc is offline
PostPosted: Thu May 22, 2025 10:44 am    Post subject: Re: Steering wheel coupler bending when tightened down Reply with quote
if you were to mount the bolts the other way, and heaven forbid, if the joint breaks, the bolt ends will connect to the flanges and give you some steering control. The way you have it now the steering wheel end will just spin around. A Ford truck has this 'feature' and it worked for me, so I adapt my VWs the same. I use longer bolts too.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
flatfour
flatfour is offline
PostPosted: Thu May 22, 2025 11:21 am    Post subject: Re: Steering wheel coupler bending when tightened down Reply with quote
I could see where that would be beneficial. I will flip the bolts around.
'68 Bug
'74 Ghia
