cdm Samba Member
Posted: Thu May 22, 2025 5:54 am Post subject: Weird valve behavior |
I inherited a 1776 engine, no idea who built it. According to the people I got it from, who got it from someone else, it never ran right so was mothballed. The heads look new and there is no carbon on the pistons. Here's the zinger; when I adjust the valves going clockwise and finishing on #2, #4 will have a huge gap, like 1/4". When I go around again one of the others will develop the large gap. No matter what I do this gap will occur.
I suspect the cam is not synced with the crank. Sound logical? Any other thoughts before I split the case? Thanks much. |
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 661 Location: CA, USA
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11481 Location: Huntington Beach, CA
Posted: Thu May 22, 2025 2:26 pm Post subject: Re: Weird valve behavior |
I had a car come in on a hook with poor drivability issues. I tried adjusting the valves first. Same issue you are having. This car had excessively worn cam bearings. EXCESSIVE! Wish cell phones had been around back then! If it had gone any further, the case would have been scrapped metal!
The adjusting of the valve would allow the cam to move from side to side. Like it was fluid, in a sense. I remember thinking, this adjuster feels weird! Got me looking. _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Fri May 23, 2025 11:22 pm Post subject: Re: Weird valve behavior |
since this is a type 1 engine it should be easy to find TDC. The crankshaft rotates twice for every time the cam rotates once. If you are on TDC of #1, going backwards 180 degrees will put you on #2, going backwards another 180 degrees will put you on #3, and another 180 will put you on #4. Another 180 will take you back to #1. Thus the crank will have rotated twice and the cam once. If you go in the same direction the engine spins when it runs then the TDC at compression firing order every 180 degrees will be 1 - 4 - 3 - 2, which should be stamped on the original generator stand in German, or if a replacement alternator stand probably in English. Photos from gallery.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 883 Location: germany
Posted: Sat May 24, 2025 3:04 am Post subject: Re: Weird valve behavior |
| cdm wrote: |
Interesting case,
imo, the three golden questions are:
a) is the cam in proper position to crank? (perfect gearing)
b) is there too much play or wear in region of cam bearings?
c) are the rivets or screws for cam gear tight?
When crank, fan belt pulley is at TDC, neither cylinder 1 or 3 is in "firing TDC", so neither the valves on cylinder 1 or 3 are slightly open "in Ueberschneidung". If not, crank position is wrong!
If you remove your oil pump, you can get access to cam and with a lever, you can check, if there is radial or axial play in cam bearings. Also you can have a look and feel for proper rivets and screws. |
