Gungey Samba Member
Joined: May 26, 2025 Posts: 10 Location: United Kingdom
Posted: Mon May 26, 2025 8:15 am Post subject: T25 torque converter |
Hi, I recently added a T25,1990 twin slider, 2.1, petrol auto to my previous list of VW's, however after replacing the fan switch and test driving it, I suddenly started loosing momentum up a hill and looked behind me to a cloud of smoke and transmission fluid smell.
My guess that that of others is the Torque convertor. The second issue, is I cant find a garage to do this replacement so I might have to break open the tool box again.
So my questions are as below if anyone can help.
Why do you need to remove the gearbox to replace the torque converter and not just drop the engine?
What are the specialist tools required to change the torque converter?
Would anyone attempt to replace the seal or replacing the entire unit?
Has anyone found a good video showing the process of autobox removal and torque replacement? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18690 Location: Retired South Florida
Posted: Mon May 26, 2025 8:40 am Post subject: Re: T25 torque converter |
Yes, you could remove the engine instead. Probably should do some more diagnosis. The torque converters rarely fail with the symptom of slippage. You may find the slipping is the result of transmission wear. The factory manual has a table with pressure test values. Short of that, dropping the automatic pan and having a look at the floor of the pan and the filter. |
Gungey Samba Member
Posted: Mon May 26, 2025 9:52 am Post subject: Re: T25 torque converter |
MarkWard wrote: |
Ok, I will have a look into that, but its leaked loads of transmission fluid all over the place. I guessed it was loosing power due to the lack of transmission fluid, but then autos are new to me. |
Posted: Mon May 26, 2025 10:14 am Post subject: Re: T25 torque converter |
Clean it really well and determine where the leaks are. There are some external seals that can be accessed. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7161 Location: Honolulu,Hawaii and France
Posted: Mon May 26, 2025 10:49 am Post subject: Re: T25 torque converter |
I bet the leak is from the TC seal, and fell onto the exhaust.
It's a million times easier and faster to drop the transmission than the engine.
Check the ATF level engine idling and hot.
TC are hard to find but can be rebuilt but like Mark said, it's likely not the culprit.
If you need parts for your rebuilder/mechanic, I have one kit left that I pieced together; I brought it to France from the US, at my brother's place.
A real complete kit: all seals/gaskets, molded pistons, clutch discs, thrust washers (and the NLA plastic ones I make and supply for rebuilders) , the 2nd gear brake band, bushings, rings and my exclusive valve body separation plate. You won't find a more complete kit anywhere especially in Europe.
They're easy to work on, anybody with decent skills and tools can do it. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Mon May 26, 2025 11:06 am Post subject: Re: T25 torque converter |
first thing you should do is check the fluid level, on flat ground with the engine running, make sure it's on the top level mark, as said before it's not often torque converters fail.
if the transmission is at fault, l would leave the engine in place, it's a MUCH bigger chunk to have to fall over while you are trying to figure it out.
what colour is the fluid, nice clean clear red ? or dirty brown.
do it look like it might have fine grey dust in it.
if it looks like strawberry milkshake, it's a paperweight, and will need a complete rebuild, and you will need to replace almost your entire cooling system
what part of the UK are you in.
the ATF you use, must be MEX/MERC compatable, this stuff seems to be, https://www.halfords.com/motoring/engine-oils-and-...24309.html
once you have found and resolved the issue while you are putting it all back together, take out the transmission cooler, join the two hoses together, and put an air cooled cooler in it, the mess you could end up with if the cooler splits internally, is not something you want to have to deal with. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Tue May 27, 2025 12:17 am Post subject: Re: T25 torque converter |
Separating the TC from the flex plate is a crucial step when pulling the transmission, you want to make sure the TC stays fully on the various shafts while removing the transaxle, failure to do this can cause you to bend the pump shaft.
Read up on getting the TC reinstalled onto the splines of the two shafts. This is a critical step and you can do serious damage to the transmission if you don't do it right. It helps to have the transaxle standing on end when you are doing this. Wire the TC to the transaxle case after you have it fully on the shaft so it can't slip off again.
You should seriously consider replacing all of the seals in the transaxle while you have it out. |
Gungey Samba Member
Posted: Tue May 27, 2025 11:25 am Post subject: Re: T25 torque converter |
Thank you one and all for the reply's.
I really wanted to book it in somewhere, but not many company's are interested (including transmission companies) which really surprised me.
So there is also an issue with the water jacket on 3 and 4 piston head, so rather than remove the gearbox, I am going to remove the engine and address this at the same time.
I will carefully remove the TC and see what the issue actually is, but based on the amount of smoke in out the back and what poured out the vent between engine and gearbox, it has to be TC related (although i am clues on autos).
Ive found a few videos and will be very careful when removing it and reinstating it.
What are the specialist tools required out of interest?
Thanks guys and girls. |
jlrftype7 Samba Member
Posted: Wed May 28, 2025 10:49 am Post subject: Re: T25 torque converter |
Gungey wrote: |
No special tools really needed. The torque converter bolts MUST be removed from the Flexplate/Converter BEFORE you remove the engine. Otherwise you will find yourself dragging the TC out of the bell housing with dropping the engine, and we want to KEEP the Converter with the Transaxle while lowering the engine.
There are 3 TC bolts, 13mm head usually on a 8mm bolt. You access them at the hole in the block, back of the engine or engine compartment that's there for that purpose.
I like to mark across the exposed section of the flexplate/flywheel with White Out typing correction fluid or some other white marker, to show easily where the bolts are going to be when I am in the process of bolting the torque Converter back up after reinstalling an engine or transaxle assembly.
You'll want to support the transaxle while lowering the engine away from it, since you're taking the engine out to work on it.
Regarding the TC seal, it's probably your culprit, but if it were me, I'd spend some money on spray solvent cans to clean off the area around the Torque Converter before dropping the engine, then run the engine, watching the bottom area of the Bell Housing for Red ATF fluid leaking out if you've still got enough fluid in the transmission to begin with. You might have to top it off to get a leak check accurate.
If it's your Torque Converter Seal, the fluid will come straight down and out.
Fair Warning- there IS a SLIGHT chance you have the dreaded Torque Converter Run-Out issue, where you need the TC rebuilt, and putting a new seal in will not stop it from leaking, as the Runout from the TC is too much for a seal to follow and keep fluid back.
I've experienced that one first hand, very frustrating.
There's also a bushing for supporting the Torque Converter that can wear, again allowing incorrect movement of the TC while it's spinning. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
dart330 Samba Member
Joined: July 19, 2004 Posts: 468 Location: Houston, TX
Posted: Wed May 28, 2025 4:13 pm Post subject: Re: T25 torque converter |
I just went through a few horrible years of a leaky Torque Converter on a newly rebuilt transaxle from German Transaxle. TC seal started leaking a few months in, had to have the trans pulled and replaced only to start leaking again a few months later. Parked it for a while as I couldn't find a shop in Houston willing to do the troubleshooting.
Ended up towing it over a 1k miles away to a specialty shop, Van Cafe Service Center. They tried everything, different kinds of seals, multiple seals, speedi sleeves and it would not stop leaking.
I shipped them a spare rebuilt TC that I had in storage and that was it. I later read that when they rebuild the TCs, they don't do anything to the center hole. If they are worn out, you may just get a bad one! _________________ Driving a 90 Carat since 2014
Previous Buses: 59 Westy, 60 Westy, 74 Bus, 82 Westy, 85 Westy, 87 Syncro
Checkout my Syncro Video: https://www.youtube.com/watch?v=0JSWhLS7jLY |
Posted: Wed May 28, 2025 10:07 pm Post subject: Re: T25 torque converter |
dart330 wrote: |
I shipped them a spare rebuilt TC that I had in storage and that was it. I later read that when they rebuild the TCs, they don't do anything to the center hole. If they are worn out, you may just get a bad one! |
There is a bushing in the TC and the shaft the bushing and seal ride on that can wear. The bushing should have been replaced as part of the TC rebuild. |
Posted: Thu May 29, 2025 5:26 am Post subject: Re: T25 torque converter |
Wildthings wrote: |
I wonder if something has changed with the QC process on this. There seem to be a lot of reports of leaky TC seals after rebuilds lately. Van Cafe also said they were no longer able to get rebuilt TCs and the supplier didn’t know if they would be doing another batch. Luckily I had a spare on hand. _________________ Driving a 90 Carat since 2014
Posted: Thu May 29, 2025 5:37 am Post subject: Re: T25 torque converter |
dart330 wrote: |
Wildthings wrote: |
I wonder if something has changed with the QC process on this. There seem to be a lot of reports of leaky TC seals after rebuilds lately. Van Cafe also said they were no longer able to get rebuilt TCs and the supplier didn’t know if they would be doing another batch. Luckily I had a spare on hand. |
What I found with ours, comparing the different TC seals out there , was this.
A fairly noticeable difference in the tension of the seal spring as you slowly moved it against the sealing area on the Torque Converter.
The usual Metal bodied seals were not as tight on the TC as some of the soft bodied seals were.
While I normally used the Metal Bodied seals always, as the Samba group has normally felt this was the only way to go, this time I switched to the soft bodied seal. And a different Torque Converter that was a used one, bought as a whole used Transaxle assembly out of Arkansas.
While I'm 100% sure our old/original TC has too much run out since neither a new bushing, nor multiple seals, nor a speedi-sleeve could help stop it leaking, the used TC I bought just got a new seal and is fine....
sigh, go figure....
No extra parts or work needed for the chronic months long leaking we were going through previously. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Gungey Samba Member
Posted: Sun Jun 01, 2025 8:54 am Post subject: Re: T25 torque converter |
I'm with the van now. The transmission fluid is clear and red. However with the engine running, it seems to me to be over full. It's wat past the dots and indeed the flat plate part of the dip stick. It shows just past the twist. I'm thinking the previous owner may have filled it when then engine wasn't running |
Posted: Sun Jun 01, 2025 10:26 am Post subject: Re: T25 torque converter |
If it’s over full, the fluid gets frothed with air and you will have shifting problems. If it’s too full it could leak past the vent etc. |
Gungey Samba Member
Posted: Sun Jun 01, 2025 10:39 am Post subject: Re: T25 torque converter |
I'm going to drain it down to the correct level this week and see how it feels. It may have done damage already, but let's hope I get lucky! God knows I could do with a little luck at the moment!!
I will keep you posted.
How do you post pics and videos on here? |
Posted: Sun Jun 01, 2025 2:13 pm Post subject: Re: T25 torque converter |
Gungey wrote: |
I will keep you posted. |
Having a tubing wrench to loosen the nut on the fill pipe at the pan is a good idea as they seem to lock into place and can take a lot of force to remove. If you intend to pull the pan, it would be nice to have a new filter on hand. The only seals that can be replaced with the transmission mounted to the engine are the two output shaft seals and several of the seals on various control rods.
https://www.thesamba.com/vw/forum/faq.php?mode=gallery |
Gungey Samba Member
Posted: Mon Jun 02, 2025 12:45 pm Post subject: Re: T25 torque converter |
I intend for now to hand pump it out from the dipstick pipe. Fingers crossed. |
Gungey Samba Member
Posted: Mon Jun 02, 2025 12:50 pm Post subject: Re: T25 torque converter |
Apologies if this is not allowed, please feel free to delete it.
This is a few vids of the torque converter smoke and me doing the dip stick (as well as van pics)
https://photos.app.goo.gl/BFmEcfxcPoyvTsGR8 |
Posted: Mon Jun 02, 2025 6:51 pm Post subject: Re: T25 torque converter |
The exhaust pipe is right under the bellhousing and when hot will burn off any ATF that drips down onto it.
You are way over filled with ATF, get the level down to where it is supposed to be and see if the leaking disappears, as when over full the ATF will foam and come out of the vent and get all over everything. The marks show the proper ATF level with the tranny is hot and the engine is running in idle or park |
