chclark Samba Member
Posted: Sun Jun 01, 2025 4:05 pm Post subject: '56 Distributor help |
Looking for a some help with my dads 56. Its been his for 20ish years and hasn't been running for years. I commandeered it and would like to get it running take him on some drives. He's just turned 80.
Anyways it has what i believe to be a 36hp. Engine number 1790383, Solex 28 PCI carb and a ZV PAU 4R5 distributor.
It currently is getting spark from the coil but not to plugs. my plan was to replace plugs, wires, cap, rotor, points and condenser. But as i started to dig into this a little I quickly realized this distributor is from a 40HP. is the pairing of thses parts ok? It ran and drove for years but I felt like it was never quite right.
Take it easy on me I am a VW newbie and have a lot to learn!
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79493 Location: Sneaking up behind you
Posted: Sun Jun 01, 2025 4:08 pm Post subject: Re: '56 Distributor help |
You have the wrong distributor, yours is for a 40hp. The correct one is a vju4br8. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Jun 01, 2025 4:26 pm Post subject: Re: '56 Distributor help |
Glenn wrote: |
You have the wrong distributor, yours is for a 40hp. The correct one is a vju4br8. |
Thanks! |
Glenn  Mr. 010
Posted: Sun Jun 01, 2025 6:45 pm Post subject: Re: '56 Distributor help |
Member #1009
#BlueSquare
Joined: April 27, 2002 Posts: 6750 Location: Pentwater, Michigan
Posted: Mon Jun 02, 2025 6:33 am Post subject: Re: '56 Distributor help |
Besides locating the correct distributor you will need to find a vacuum advance line as yours was modified to fit with a 40 hp distributor. You should be able to find both in the Samba classifieds as they are not available new anymore. Good restored units can be had. _________________ Roads Scholar
Member# 2059 |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11155 Location: Huntington Beach, CA
Posted: Mon Jun 02, 2025 8:00 am Post subject: Re: '56 Distributor help |
tasb wrote: |
Besides locating the correct distributor you will need to find a vacuum advance line as yours was modified to fit with a 40 hp distributor. You should be able to find both in the Samba classifieds as they are not available new anymore. Good restored units can be had. |
I have not purchased one of these but Wolfsburg West offers a vacuum line for that. It is the metal line with a thread end at each end. Again, I have never purchased one from them but it is listed.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111129493A _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Mon Jun 02, 2025 5:24 pm Post subject: Re: '56 Distributor help |
That would be the one. There is also an adaptor fitting that you will need at the carburetor.
Classifieds search under: vacuum line fitting. _________________ Roads Scholar
Member# 2059 |
