Jumps out of 1st gear on take off.
soggz
soggz is offline
PostPosted: Sun Jun 01, 2025 11:35 pm    Post subject: Jumps out of 1st gear on take off. Reply with quote
Hi all. โ€˜72 1600.tp.
As title. Pull away and build the revs, then jumps out of gear. New clutch, cable adjustment right.
Educated guessโ€ฆ would this be anything to do with the plate under the gearstick loose/not adjusted correctly? If so, is it a case of loosening the two bolts, putting it into 1st gear, then re tighten?
Thanks.
Abscate Premium Member
Abscate is offline
PostPosted: Mon Jun 02, 2025 12:52 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
FIrst check, motor mounts. Make sure something isnt broken and your engine isnt getting ready to fall out. First sympton, pullnig it out of gear.
Next symptom , lots of loud noises.
soggz
soggz is offline
PostPosted: Wed Jun 04, 2025 8:56 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
No. All the mounts are fine. Iโ€™ve only just put the motor back in after a full rebuild. Was thinking more about the cab floor shift plate not lined up properly?
halfassleatherworks
PostPosted: Wed Jun 04, 2025 9:15 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
check the shift tube coupler at the front of the trans.
SGKent Premium Member
SGKent is online now
PostPosted: Wed Jun 04, 2025 9:35 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
the indents in the selector hold the shift rail in position. If you can fully engage first gear and it pops out, it is a more serious problem. The shift linkage is designed to shift the different shift rails, not hold it in gear. If you can put it in first gear and not hit the E-brake or ashtray, the problem is in the transmission. That is my opinion. Once the main bearing wears into the nose cone, the gear does not fully engage and that can wear it funny and cause it to pop out. Sometimes it can be saved with the plate from Weddle.
You can see the three shift rails on the right. The shift linkage moves those and they in turn move the gears, and lock in place with ball bearings and pins that lock into indents. The three are made so only one can be engaged at any time, and when all three are lined up it is in neutral. So if you can push it all the way into first gear, the shift rail should be locking the gear in place. As the big center bearing wears into the nosecone, the whole mainshaft and gears change tolerances, and bad things happen. Weddle makes a steel plate that pushed the main gear back into place. It is a work around kind of fix but it may help. To use it the nosecone has to be milled the thickness of the plate.
These are 091 photos but 002 is almost the same.
first gear
soggz
soggz is offline
PostPosted: Fri Jun 06, 2025 11:00 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
first gear
Thank you for the detailed reply.
I have not long had the gearbox off to replace the nose cone seal. I recognise those three selectors, but I donโ€™t truelly know about gear boxes. When selecting 1st in the cab, my handbrake is on 3 clicks out and the gear lever does not hit it. Thatโ€™s why I was wondering if the floor plate need a to go forwards a bit more.
Please be patient as I donโ€™t know too much about gearboxes at this stage.
PostPosted: Fri Jun 06, 2025 12:12 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
well the issue is that if you push it forward into first gear, and the gear knob stops moving before hitting something, then in my opinion it is going into first gear, and the selector and gears should hold it locked there. Sloppy shifts, having trouble finding a gear would be a stop plate or linkage issue. But you are finding first gear - it just isn't staying in it. You are in the UK, is this correct? Maybe MikedJames may know someone who can assist you. He is in Hampshire.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=298861
soggz
soggz is offline
PostPosted: Fri Jun 06, 2025 3:14 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Yes. I know of him from a site I used to belong to. The Late Bay.
Unfortunately, Iโ€™m not on it anymore, due to being banned for my opinions on something which seems to be happening more lately. I was on it since 2014 maybe earlier, but thatโ€™s another story.
Thanks anyway.
PostPosted: Fri Jun 06, 2025 3:56 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Thanks anyway.
we've all been banned somewhere and sent home for something these days. Just this statement alone would get me banned on many forums I belong to but don't go because I don't like having to be dishonest to appease others. Send him a PM and see if he can help or knows who can.
PostPosted: Fri Jun 06, 2025 6:25 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
as Abscate said, do check your motor mounts and the transmission mount. There are also a set of mounts above the bell housing that break with time. If the engine is torqueing or moving, it could be pulling it out of gear just like you are shifting it.
aeromech
aeromech is offline
PostPosted: Fri Jun 06, 2025 9:01 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Have you drained the gear oil?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
soggz
soggz is offline
PostPosted: Sat Jun 07, 2025 5:24 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Hi. Yes, as I replaced the nose cone seal, as it was leaking. I put everything back as I found it. The oil was the usual fowl smelling black stuff. Replaced with the recommended oil.
PostPosted: Sat Jun 07, 2025 6:01 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
was it jumping out of gear before you replaced the nose cone seal, and did you take the nose cone off and do anything inside it?
soggz
soggz is offline
PostPosted: Sat Jun 07, 2025 11:31 pm    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Yes,mit was jumping out of first before I took the nose come off.
PostPosted: Sun Jun 08, 2025 12:57 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
If that is the case, I think you need to
1. Check the motor and transmission mounts to be sure they are intact and not broken. Check the grub screws for tightness, and the shift coupler for wear. If you find issues, fix them then see if that helps.
2. Prepare yourself to either add the steel plate yourself and hope that does it, or send your transmission to be rebuilt. You can also replace the ball (doughnut) in the nose cone when you are in there and check the selector.
The selector rails pull the shift fork, which engages the gears. Only one shift rail can be used at a time - so when the 1 - 2 rail is moved one way the shift fork moves the slider hub to lock the transmission in 1st, and when it is moved the other way it locks it in 2nd. Before 3 - 4 or R can be selected, the 1 - 2 rail has to return to the neutral position. I mean sure, look over the grub screws for tightness, check the coupler at the back, check the mounts, but be prepared to have the transmission repaired before 1st gear is damaged.
It takes more cost in specialty tools, and a lot of knowledge to rebuild a bus transmission than to pay to have one done.
Below is a video of the shift rails being moved with the gear carrier mounted in a jig. The issue you may be having is that the whole gear cluster has shifted if the main bearing has eaten into the nose cone, which they all do. The steel plate pushes the bearing back where it should be, but it will be back in time. Hard to say what the issue is for sure but that would be my guess. Once the gear wears funny it will keep popping out no matter what, so you want to stop it as early as possible.
soggz
soggz is offline
PostPosted: Sun Jun 08, 2025 2:40 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Thanks.
That looks complicated, but seeing it, makes me understand the internal workings. When I had the nose cone section off, I saw no wear or witness marks of anything that could have been out of place or worn. There was no play in the large bearings next to the selectors, so Iโ€™m guessing that everything is as it should be. Iโ€™m going to get under the bus again later today to see if anything is โ€˜offโ€™, or not how it should be. I know that the first connection from the bottom of the gear lever where the first wired square topped bolt is, is pretty much rusted in and doesnโ€™t move. The rear shaft coupling was new a few years ago, and the wired bolt is present, so no movement there. All the engine mount runners and gear box to chassis mounts seem fine, as I examined them all on putting the engine and gearbox back in about a month ago. So from the lever to the box, everything looks as it shouldโ€ฆ
Abscate is offline
PostPosted: Sun Jun 08, 2025 2:43 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Insufficient proof to rule that out. The new couplers are junk, so it easily could have deformed the cage and be the root cause.
Remove and inspect.
Nitramrebrab72
Nitramrebrab72 is offline
PostPosted: Sun Jun 08, 2025 4:35 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
To narrow down the cause of the problem I would disconnect the gear selector linkage at the gear box and manually select 1st using the lever coming out of the gearbox case and drive as before .. If it still jumps out then it's a gear box problem , if it stays in then it's a gear linkage problem.
Abscate is offline
PostPosted: Sun Jun 08, 2025 7:31 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
Nice troubleshooting strategy, there.
PostPosted: Sun Jun 08, 2025 10:38 am    Post subject: Re: Jumps out of 1st gear on take off. Reply with quote
it is a good idea.
That said, to the OP, unless you knew what to look for, it would not have been obvious. Read these quotes below from a recent thread. There are many more like it but this is a recent one. In his photo like this, you can see where the main bearing has eaten its way forward. It should be flush. By all means check the coupler and grub screws etc., but I think in the end you will find this as a possible problem. It may have already worn out the slider hub and the gear so it no longer locks the gear in place. Here is a good explanation. Rick Long retired so his website is no longer available but there is a copy of a technical page on archive.org. Be patient for it to load. https://web.archive.org/web/20180128224141/http://www.longenterprises.com/remachined_sliders.htm
poundman wrote:
While I am waiting for the correct needle bearing I have shifted to the transmission (pun intended). I replaced the final drive seals and caps. Then I replaced the seal behind the throw out bearing. My first question, is this the correct position of this tube. I didn't pay attention to how it was removed. It has some opposing holes, I am not sure if they should go up/down or left/right or does it even matter?
Next, I switched to the nose. If you look at the original pictures of the transmission, it appears it was leaking from the nose area. Not sure if the seal or the gasket of the nose cone. It had a lot of build up.
I plan to replace the seal so I needed to remove the nosecone. Here are the pictures. Do you seen anything out of the ordinary? I read on ratwell about the ball joint that wears out. You can see mine is worn out, and the plastic shavings in silver at bottom of cone.
Would you replace with a steal ball joint or try the original plastic type?
https://weddleindustries.com/products/004-301-241-A-HD/004-301-241-A-HD
https://www.heritagepartscentre.com/us/004301241a-transmission-hockey-stick-pivot-ball.html
When I reassemble, should I put some grease on these moving parts?
poundman wrote:
Wildthings wrote:
Your are getting thrust wear to the nose cone, not sure what the limit is considered to be. You can buy a steel plate to install that eliminates this wear. As to the ball, if I know for sure I could get a factory quality plastic one I would go that route, but if not maybe go with the metal one.
Can you tell me what you see that indicates thrust wear? Was it all the oil build up on the outside, or something else, like the worn out ball joint?
The thrust plate you mention, is this the plate? Does this replace the gasket? or would I but in as gasket on both sides of this plate? And as @SGKENT mentions, I need to have cone milled down to the thickness of plate.
Thank you.
PS. I have a 002 transmission.
https://weddleindustries.com/products/9372/9372
poundman wrote:
I found this image in another post. Is this a 5 rib 002 from 74-75 Mine is 3 rib 002. I don't have the spring or the bracket around the selector link shaft. Tell me this is just unique to the 5 rib 002. These parts are not mentioned or pictured in the Bentley either.
Also, how does the shaft stay up, is it just ride on a bottom of the of the cone?
Original thread:
SGKent wrote:
take a photo and post it. The 091 selector bracket is similar but slightly different than the 002 one.
They all would need 002-301-239 and the selector to ride on a pin thru the bracket. I think that the 091 has the second bracket with a spring on each side.
https://weddleindustries.com/products/shift-rails-...id=1000356
091 version
This may be the 002 version (from early bay.com)
SGKent wrote:
in answer to the nosecone question. As the main bearing moves it slowly eats into the softer aluminum, which the arrow clearly shows. This allows the shaft and associated gears to move forward and change the mesh. As those gears wear, a slope on the teeth is created and eventually they, especially 4th, will start having issues that could include popping out of gear under certain loads. The fix is to mill the nose cone flat again and install the metal plate. The bolts are too short for a paper gasket on each side. Some people use RTV on both sides, some use one paper gasket and RTV. The 002 models were worse doing it than the 091 because the 002 main bearing does not have the half moon key in it to keep the bearing from spinning in the case, although that does not even stop it from happening. That big circle holds the main bearing, shaft and gear cluster in position.
