Travel Limiting feature on front end of buggy
Turbopaul
Turbopaul is offline
PostPosted: Mon Jun 02, 2025 9:51 am    Post subject: Travel Limiting feature on front end of buggy Reply with quote
Hi guys, wondering what my options are for keeping the front end travel off the max travel of the ball joints. Right now they are the limiting factor which is ok but I want to install something that will pull the arms upward to keep the suspension off the end travel of the ball joints. I had wire cables but that was a pain for adjusting. What do you guys have for options on this. Thanks
LintonBuggy
LintonBuggy is offline
PostPosted: Mon Jun 02, 2025 3:48 pm    Post subject: Re: Travel Limiting feature on front end of buggy Reply with quote
You want to protect the useful range of the shock absorbers as well as the useful range of the ball joints.
A few ideas to get you started (at least this will give you some search terms to further refine your search):
Hook And Rod Suspension Stops
https://www.kartek.com/parts/vw-ball-joint-front-a...ravel.html
Suspension Limiting Strap
https://www.kartek.com/parts/nylon-7-inch-long-bla...-ends.html
Bump Stops
https://www.kartek.com/parts/curved-top-bump-stops-1-x-1-34-x-1-716-red-pair.html
Derickpete
Derickpete is offline
PostPosted: Mon Jun 02, 2025 3:56 pm    Post subject: Re: Travel Limiting feature on front end of buggy Reply with quote
I run limit straps that are 1” shorter that full drop. They will stretch 1/2 inch when they hit.
Schepp
Schepp is offline
PostPosted: Tue Jun 03, 2025 2:19 pm    Post subject: Re: Travel Limiting feature on front end of buggy Reply with quote
A quick little video I made of how the hook & rod setup works. This was when I was building my front BJ Beam.
https://www.youtube.com/watch?app=desktop&v=VaDFerh7qIg
If I did it again, Id run a limit strap to softly stop the action. And only one hook to stop up travel.
The constant chatter from the bottom hook hitting is a bit annoying.
A note on limit straps. For every foot they stretch half an inch. This must be factored in when ordering the length.
