Information wanted on these safari window props
mikey1two
mikey1two is offline
PostPosted: Mon Jun 02, 2025 7:58 pm    Post subject: Information wanted on these safari window props Reply with quote
Saw these at a local VW show and was wondering more about them. Seems to be some sort of safari prop arm?
thom
thom is offline
PostPosted: Tue Jun 03, 2025 12:54 pm    Post subject: Re: Information wanted on these safari window props Reply with quote
That's to poke out the passenger's eyeball
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
crofty
Judas of the North
crofty is offline
PostPosted: Tue Jun 03, 2025 2:08 pm    Post subject: Re: Information wanted on these safari window props Reply with quote
And bend your hot air vents
HamburgerBrad wrote:
Malokin Martin
Malokin Martin is offline
PostPosted: Tue Jun 03, 2025 2:57 pm    Post subject: Re: Information wanted on these safari window props Reply with quote
Sure would be nice not to have to have them gorilla tight to get on the freeway….
schnidlee
schnidlee is offline
PostPosted: Tue Jun 03, 2025 4:48 pm    Post subject: Re: Information wanted on these safari window props Reply with quote
They look ridiculous!
A guy on an Australian forum 3D printed these and was going to have them cut from stainless, seems like a much more logical solution, I'm not sure if he ever made the steel version or it was just a prototype.
sled
sled is offline
PostPosted: Wed Jun 04, 2025 9:17 am    Post subject: Re: Information wanted on these safari window props Reply with quote
I don't understand the point of either style prop....you know there are wing nuts you can just tighten to hold the window in place right?
drive your split.
mikey1two
PostPosted: Fri Jun 06, 2025 10:52 am    Post subject: Re: Information wanted on these safari window props Reply with quote
I’m guessing that they are used as a prop then, it was something “new” that I recently saw after visiting a VW show. A better question then would be, what type of washer are you using on your safari windows to keep them open while doing 60 on the freeway without as ‘Malokin Martin’ describes as being gorilla tight? Are you using plastic or fiber type washers to keep the windows open? I’m assuming the fiber washers would work better. And then such a device that would “bend your vents” and “poke out your passengers eye” wouldn’t be needed.
Malokin Martin
PostPosted: Fri Jun 06, 2025 11:45 am    Post subject: Re: Information wanted on these safari window props Reply with quote
Bought the expensive fiber ones. Still not easy to get them to stay half open @70. Not saying this guy is a genius, just that it’s an intriguing idea
