Resonating noise
Lucastein
Lucastein is offline
PostPosted: Tue Jun 03, 2025 5:33 pm    Post subject: Resonating noise Reply with quote
Hello all,
I am just reaching out for some info, my bus tends to make a resonating noise while driving, quite a low end, mild thudding, however the sound does not happen while my clutch is pressed in.
If I'm parked and I Rev it, I get the sound, parked and Rev it with the clutch pressed in I don't get that noise. Could it potentially be too much movement at the crank (aka due for a reshimming?)
Any input would be great before I remove the engine. Cheers!
It's a 71 westy (1641)
timvw7476
timvw7476 is offline
PostPosted: Tue Jun 03, 2025 6:03 pm    Post subject: Re: Resonating noise Reply with quote
a worn bearing in the transaxle. Known failure point in the 002 transaxle.
There is a steel support plate that can be fitted to support the new roller bearing.
