Brake Performance '66 beetle
66bugguy
66bugguy is offline
PostPosted: Wed Jun 04, 2025 9:51 pm    Post subject: Brake Performance '66 beetle Reply with quote
I have EMPI disc brakes installed on my 66, but the pedal it feels like I have to press it like 4.5 inches before I get any braking, and most of the brake dust is on the rear wheels and not the fronts, which seems opposite to how it usually should be biased. The brakes have been bled, I'm not sure if this is just the brake performance to expect or if I have something wrong with my car.
Thanks
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Wed Jun 04, 2025 10:28 pm    Post subject: Re: Brake Performance '66 beetle Reply with quote
Something wrong. How much freeplay at the pedal?
Jimbo
TDCTDI wrote:
67rustavenger wrote:
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Thu Jun 05, 2025 2:02 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
That much pedal movement sounds like a bad master cylinder or a circuit with air still in it
Robert in Memphis
Engine rebuild thread
runamoc Premium Member
runamoc is offline
PostPosted: Thu Jun 05, 2025 6:12 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
Disc brake MC have larger bores so that more fluid is 'pumped' out when pressed. Do you have a MC made for disc brakes?
https://www2.cip1.com/c31-611-015-000/
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
slave1pilot
slave1pilot is offline
PostPosted: Thu Jun 05, 2025 6:19 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
it would also help to know if its 4 wheel disc or front disc/rear drum
Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Jun 05, 2025 7:25 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
If you have 4 wheel disc brakes you probably need a brake proportioning valve to adjust the ratio between front and rear. If you have only front discs it is common to have more pedal travel than 4 wheel drums with a peak adjustment. The original master cylinder with a front disc brake karmann Ghia had an internal valve that metered the pressure between the front and the back. When I did a front disc conversion on a 72 bug about 40 years ago I tried to get a Ghia master cylinder replacement and could not find it anywhere. NOS might be the only source for that. I hope this helps-bob
runamoc is offline
PostPosted: Thu Jun 05, 2025 9:21 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
I put discs all around on my Ghia and used this MC without any valve
https://www2.cip1.com/c13-16-9554/
viiking
viiking is offline
PostPosted: Thu Jun 05, 2025 5:26 pm    Post subject: Re: Brake Performance '66 beetle Reply with quote
The original OEM ATE disc brake introduced in Europe on beetles (and Ghias in the US) did not have any special valve. Yes it had specific drillings internally but not a valve per se.
The pedal stroke and therefore the volume of fluid displaced was 28mm at 19.05mm bore.
The drum brake dual circuit master cylinder split this displacement to 15.5mm front and 12.5mm rear.
The disc brake dual master cylinder split this displacement evenly at 14mm/14mm.
The two MC's were therefore NOT the same i.e drum v disc.
This difference was to compensate for the differing volumes required to provide full travel of either the brake cylinder or the calliper piston. Of course using different or aftermarket discs, or drum v disc MC's may require a rethink of how much volume is require per a full stroke application of the pedal. Hence it is critical to match the MC to the disc brake set up. Only knowing the requirement of both will allow you to not suffer having a "long pedal" as the OP has stated.
Unfortunately, I'm not sure how much of this information is ever provided by the vendors selling the MC's or disc conversions. The maths is pretty simple to determine the volumes required from the volumes of the calliper and brake cylinders if fitted. That's why I try and use OEM replacement parts which in my case is ATE. A lot more money but worth it in having less hassle.
If the MC does not have enough volume to expand the calliper piston and the brake cylinder(master) in BOTH of the separate circuits you will get the scary feeling of the excessive pedal travel. A second pump should bring the pedal up to a more normal pedal height. If it doesn't there are other problems. Yes other issues such as brake rod adjustment or air in the system can also be the reason.
Yes but a bigger bore MC actually reduces the pressure developed for the same pedal effort. Excessively large bores do not necessarily improve brake performance and why vacuum boosters are fitted to more modern vehicles to reduce brake effort.
66bugguy
66bugguy is offline
PostPosted: Fri Jun 06, 2025 12:03 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
Its a 67’ dual circuit one i installed instead of the single 66 one, i guess bleeding the brakes again wouldn't hurt.
66bugguy
66bugguy is offline
PostPosted: Fri Jun 06, 2025 12:04 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
No, its a stock 67 dual circuit one.
66bugguy
66bugguy is offline
PostPosted: Fri Jun 06, 2025 12:05 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
4 wheel EMPI disk brakes all around
Bobs67vwagen
PostPosted: Fri Jun 06, 2025 3:37 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
Viking that was very educational information that you posted. In the US , I have never seen a vendor selling the karmann Ghia disc brake master cylinder. Do you have a part number and a source for the ATE Ghia master cylinder? Also since the original poster has now stated that he has 4 wheel disc brakes do you agree that a proportioning valve could be set to regulate front and rear pressure for this setup? Thanks Bob
viiking
viiking is offline
PostPosted: Fri Jun 06, 2025 9:32 pm    Post subject: Re: Brake Performance '66 beetle Reply with quote
Unfortunately mine is a RHD disc brake car so it won't fit yours. It was originally VW number 114 611 017E. The RHD are much harder to find but my original source was here:
https://www.heritagepartscentre.com/us/catalogsearch/result/?q=ate%20master%20cylinder
There you can see a RHD and a German LHD (not necessarily ATE) available too.
As far as I can see from the original German documentation the LHD MC numbers were:
113 611 017, and the suffixes determined the year models. These were suitable for both the Beetle and the Ghia.
If you can tell me the VIN number range I can give you a more accurate answer.
Re the proportioning valve, I have seen posts from various people that support with or without. I can't comment either way other than my own experience with OEM disc up front and drum at rear. However if the stroke volume of the MC is known and the calliper volumes are known then I would think there would be no need for a proportioning valve as the MC takes care of that to a great extent.
Also IMO the need for 4 wheel discs on a car that is less than 1 tonne with weight distribution as it is, is unnecessary and is unlikely to provide better braking than what is available with the disc - drum set up. There are other VW solutions to improve braking including wider drums and brake shoes from other VW types.
As I indicated in the earlier post, you really have to look at what combination of components you are using. Unfortunately many people do not realise that there are nuances with the parts that they buy and (in general) the vendors just seem to sell "one size fits all" parts that may or may not be compatible.
Going on the ATE website gives this answer for Ghias 64-74. There are other year ranges so you could perhaps fill in for different years.
https://web.tecalliance.net/ate/en/parts/cars/part...groups:258
Pumping that number into google gives lots of hits. They appear to be mostly in Europe so you can search for other places. Here is just the first one that came up on my search.
https://spareto.com/products/ate-brake-master-cylinder/03-2119-8511-3
Bobs67vwagen
PostPosted: Sat Jun 07, 2025 7:27 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
Great info viking-thanks for posting it. I am sure that I am not the only person in the US who over the years has thought of getting the correct master cylinder for a Ghia front disc setup with standard rear drums. Much appreciated-Bob
Cusser
Cusser is offline
PostPosted: Sat Jun 07, 2025 9:48 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
That's actually a very good idea !
EVfun Premium Member
EVfun is offline
PostPosted: Sat Jun 07, 2025 3:06 pm    Post subject: Re: Brake Performance '66 beetle Reply with quote
It is doubtful that you have a US spec ‘67 master cylinder, more likely a ‘67 up replacement. I say this because you didn’t have your disc brakes running HOT. Here is a picture of a ‘67 master cylinder, complete with the external residual pressure valves:
Most likely you have the “universal” replacement master cylinder sold in the US. It has restriction drillings so drum brakes don’t release too fast instead of residual pressure valves that would leave disc brakes dragging.
If your brakes start halfway down the travel you have a serious brake problem! Since you see noticeably more wear at the rear my guess would be either serious air in the front brakes or the front half of the master cylinder doesn’t work. Even stock, the ‘60’s Beetles had brakes that bettered many American cars of the era.
Wildthings wrote:
viiking
viiking is offline
PostPosted: Sat Jun 07, 2025 4:39 pm    Post subject: Re: Brake Performance '66 beetle Reply with quote
...and following on from EVfun and my diatribe explanations above Bentley states:
"Caution -
The tandem master cylinder for disc brakes is not interchangeable with tandem cylinders for drum brakes".
So if 66bugguy has an existing dual circuit drum brake master cylinder fitted with residual pressure valves on a new Empi brake setup, this may be part of the problem.
So if you originally had drum brakes or you have bought a new brake master cylinder you are more likely in the US to NOT get a MC that has the correct internal drillings and variations in the stroke. This more likely leads to the many issues that we see with people blaming the MC for poor brake performance.
As most (not all) Beetle models sold outside of North America came with discs as standard from the mid-late 60's the search for MC's perhaps would yield better results from Europe.
Perhaps our European or more specifically German members could comment further on what their understanding is on the correct MC's available for LHD.
EVfun is offline
PostPosted: Sat Jun 07, 2025 8:04 pm    Post subject: Re: Brake Performance '66 beetle Reply with quote
"Caution -
I understand, and showed an original Bug dual circuit master cylinder. The original dual circuit master cylinder used those external residual pressure valves for drum brakes, and also had a slightly different stroke length in each half between disc and drum cars. We have been using a universal replacement for years. I have one in my buggy with 4 wheel drums and no residual pressure valves.
Here is look at the common options for master cylinder replacement today:
CIP
JBugs
Mid American Motorworks
Heritage Parts Centere
Note that they are for the Bug and Ghia. The later Ghia's covered have front disc brakes in US trim. Can you even find the originally correct disc/drum and drum/drum master cylinders?
If all your brakes are aftermarket based on some Golf parts, or whatever, you need to consult whoever made your braking system. If it isn't using stock parts at the wheels it may not be appropriate to use a stock master cylinder of any year.
Wildthings wrote:
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Sun Jun 08, 2025 12:50 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
What is a “residual pressure valve” and where is it located in or on a vintage VW brake master cylinder? Just trying to understand what I’m looking at in that picture of a dual circuit cylinder above. Those external protuberances with electrical connectors look like hydraulic brake light switches to me.
EVfun is offline
PostPosted: Sun Jun 08, 2025 7:24 am    Post subject: Re: Brake Performance '66 beetle Reply with quote
You have spotted the brake light switch. If you look at the right hand brake light switch you can see a piece of metal brake line still attached to the master cylinder. You can see the bubble flare nut attaching that line to the master cylinder. If you look closely you will see that the brake line doesn't screw directly into the master cylinder. There is another larger nut screwed into the master cylinder that the brake line attaches too. That is the residual pressure valve for Bugs with dual circuit master cylinders. There is one in the front circuit as well, with no brake line is attached to it.
A Ghia with disc brakes would not have had the front residual pressure valve and the location of that screw in the top would have been a couple millimeters different.
On modern replacement dual circuit master cylinders for Bugs and Ghias the brake lines screw directly into the master cylinder above the brake light switches. If you look inside those holes you will see that the fluid has to pass through a small drilling to get into and back from the brakes. This is the restriction drilling that eliminates the need for residual pressure valves on stock Bugs with drum brakes.
The single circuit master cylinder is completely different. The residual pressure valve is internal to it, attached to the end of the internal piston return spring. When disc brakes are used with a single circuit master cylinder that will need to be removed and an external residual pressure valve should be used if rear drum brakes are retained.
Wildthings wrote:
