800cc "Single Port"
Dusty1
Dusty1 is offline
PostPosted: Fri Jun 06, 2025 12:10 pm    Post subject: 800cc "Single Port" Reply with quote
Working on a deal for a Bug with the ubiquitous extra "pile o' parts". The interesting feature of the pile is 2 1/2 extra motors. We could calculate the 1/2 motor as the usual "Well, it looks like around half the parts we need for another motor" but no. This one has been band sawed in half for aircraft use. I see half a counterweighted crank, half a cam and of course half a case the hard way. There's an extra dual port cylinder head for when I get around to sawing that in half.
Hey! I just figured out what to do with those heads that have one destroyed combustion chamber.
"Dusty, just buy a durn Rotax."
oprn
oprn is offline
PostPosted: Fri Jun 06, 2025 1:42 pm    Post subject: Re: 800cc "Single Port" Reply with quote
Put the engine in the Buggy and see if you can make 45 mpg at 50 mph! Take the CR up to 9/1, use a vacuum advance distributor and a 28mm Solex. A 800cc well tuned engine just might do it! Oh yes, drum brakes and skinny tires too.
I would do that in a heart beat just for the bragging rights!
Dusty1
Dusty1 is offline
PostPosted: Fri Jun 06, 2025 5:30 pm    Post subject: Re: 800cc "Single Port" Reply with quote
there are parts that shouldn't be cut in half such as rocker arms.
I need to look at my "modified" crank. Seems they lopped off the section that accepts the timing gears.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jun 06, 2025 5:53 pm    Post subject: Re: 800cc "Single Port" Reply with quote
How about 2/3 of an engine?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rayjay
rayjay is offline
PostPosted: Fri Jun 06, 2025 5:59 pm    Post subject: Re: 800cc "Single Port" Reply with quote
Many moons ago when the ECTA was running at Maxton NC I contemplated a 1000cc ACVW powerplant. 250cc per hole was what I was thinking about. Much later it occurred to me that the better bet might be a 500cc per hole twin so I read a bunch of homebuilt aircraft info. For car use the best bet would be to not cut anything in half but instead just leave off cylinders 2 and 4. This way you have an intact belhousing and flywheel mounting arrangement. Just have to plug off all the unnecessary oil passages.
NJ John
NJ John is offline
PostPosted: Fri Jun 06, 2025 6:36 pm    Post subject: Re: 800cc "Single Port" Reply with quote
Pics please.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Dusty1
Dusty1 is offline
PostPosted: Sat Jun 07, 2025 12:51 pm    Post subject: Re: 800cc "Single Port" Reply with quote
Think of all the ugly weight you'd eliminate. Seems to me you would need to leave two of the rockers off each head and plug your newly formed oil leaks at the lifters. Plug the oil passages in the crank to the two missing connecting rods.
NJ John wrote:
Pics please.
One of these days I'll dig the debris out from under the 14' U-Haul full of parts I just got. Otherwise it looks like half a case, half a crank and half a cam modified by a real "live in the moment!" kinda guy. "Live in the moment!" as in do the obvious part first, worry about makin' it work later.
Ooh that's cool! I want one.
Come to think of it wouldn't be the first time I had a size cylinder running on four. We're talkin' my old farm truck and just about every six cylinder Chevy I've owned at one time or another.
rayjay
rayjay is offline
PostPosted: Sat Jun 07, 2025 3:37 pm    Post subject: Re: 800cc "Single Port" Reply with quote
Come to think of it wouldn't be the first time I had a size cylinder running on four. We're talkin' my old farm truck and just about every six cylinder Chevy I've owned at one time or another.[/quote]
There's plenty of videos of guys doing the conversion at home. Sealing the back end of the crankcase is quite fiddly. Then you have some welding on the heads to create a valve cover gasket surface on the sectioned head. For my idea I think leaving the heads as is along with installing the other 2 cylinder barrels sans pistons and rods and torqueing it all down like a stock motor.
NJ John
NJ John is offline
PostPosted: Sat Jun 07, 2025 3:51 pm    Post subject: Re: 800cc "Single Port" Reply with quote
There’s actually this one for sale.
https://www.thesamba.com/vw/classifieds/detail.php?id=2747805
Dusty1
Dusty1 is offline
PostPosted: Sat Jun 07, 2025 5:54 pm    Post subject: Re: 800cc "Single Port" Reply with quote
Oh, cool! I need to figure out a way to bolt a flywheel to the other end.
The one I have is the back half.
NJ John
NJ John is offline
PostPosted: Sun Jun 08, 2025 10:12 am    Post subject: Re: 800cc "Single Port" Reply with quote
Put it in a motorcycle or mid engine trike.
oprn
oprn is offline
PostPosted: Sun Jun 08, 2025 2:47 pm    Post subject: Re: 800cc "Single Port" Reply with quote
That would be cool too!
Dusty1
Dusty1 is offline
PostPosted: Tue Jun 10, 2025 5:12 am    Post subject: Re: 800cc "Single Port" Reply with quote
Not to be a ghoul but I may inherit a chopped 1950s BMW. The bike was modified into a hooligan bike / street fighter back when the current crop of street fighters were only a glimmer in their grandma's eye. The bike has sidecar gearing, quicker stop light to stop light, a James Dean (or Bud Ekins or Steve McQueen) style Bates seat and reversed pillion as well as other cool period parts and modifications.
Who would do that to a BMW?!
Make restorers cringe.
Same rich uncle has an astonishingly low mileage L88 Vette in his living room. It hasn't moved in 50 years.
I'll reiterate my stance on trikes especially VW based trikes: Trikes combine the worst characteristics of motorcycles with the worst characteristics of cars.
NJ John
NJ John is offline
PostPosted: Tue Jun 10, 2025 7:39 am    Post subject: Re: 800cc "Single Port" Reply with quote
Ok, how about a super MPG bug or Ghia?
Does the BMW have the separate trans that’s sometimes used for VW swaps?
Dusty1
Dusty1 is offline
PostPosted: Tue Jun 10, 2025 8:29 am    Post subject: Re: 800cc "Single Port" Reply with quote
Yeah the older BMWs can be mated to VW engines.
Super MPG: Sometimes tiny motors get crappy fuel economy because they need to work too hard. Trick is to get as much power or more compared to stock from a smaller motor. My favorite is the old Geo Metro (Suzuki) 1 liter three cylinder.
NJ John
NJ John is offline
PostPosted: Tue Jun 10, 2025 9:14 am    Post subject: Re: 800cc "Single Port" Reply with quote
Metro’s were 50mpg. Not bad for the early 90’s. Drove plenty of them when working the lube rack at a Chevy dealer. Turbo Chevy Sprints, too.
oprn
oprn is offline
PostPosted: Tue Jun 10, 2025 9:29 am    Post subject: Re: 800cc "Single Port" Reply with quote
I might be totally out to lunch here but I am begining to think that ore size is related to MPG more so than displacement. A smaller bore size to get better flame travel and a more complete burn.
I cannot think of any engine in the past with a bore approaching 4" that got good fuel economy. I don't know about the modern crop of engines though.
