GoodGrief88 Samba Member
Joined: June 07, 2025 Posts: 3 Location: New Hampshire
Posted: Sun Jun 15, 2025 3:15 am Post subject: 2.5L runs rough in third gear. Black smoke |
My 1993 with the 2.5L has been sitting for about two years when we bought it. Changed the oil, fuel and air filter, treated what gas was in the tank and added ten gallons of 93 octane. At first it ran rough and smoked all the time but now after putting maybe five miles on it it's pretty much only running rough once the transmission goes into third gear. That's when I get the black smoke too. Any advice would be greatly appreciated as I really don't want to just throw parts and money at it. Thanks |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 477 Location: Asheville, North Carolina
Posted: Sun Jun 15, 2025 5:14 am Post subject: Re: 2.5L runs rough in third gear. Black smoke |
Could be sticky/leaky injectors, running a bit rich. Add some Seafoam gas treatment to the tank and drive it some kore. It just might clear up. _________________ If it ain't broke, don't fix it! |
Posted: Thu Jul 17, 2025 2:55 pm Post subject: Re: 2.5L runs rough in third gear. Black smoke |
I've tried seafoam and 93 octane gas but it's still running rough and what i would say is rich because of the black smoke. Could a bad coolant temperature sensor be telling it that it needs more fuel than it really needs? |
TheOneTrueQuux Samba Member
Posted: Fri Jul 18, 2025 8:58 am Post subject: Re: 2.5L runs rough in third gear. Black smoke |
GoodGrief88 wrote: |
Absolutely. An incomplete list of things that can cause this:
Torn fuel pressure regulator diaphragm.
Bad MAP sensor in ECU.
Bad coolant temp sensor.
Bad ground, causing bad sensor readings.
Sticky injectors, but usually they cause lean running, not rich. _________________ Josh
1995 EVC
ACU, 098 |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23791 Location: NYC/Upstate/ROW
Posted: Fri Jul 18, 2025 9:53 am Post subject: Re: 2.5L runs rough in third gear. Black smoke |
A compression test to determine what shape the engine is in order.
It could easily be a paperweight and why the car sat. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
CdnVWJunkie  Samba Member
Joined: February 01, 2004 Posts: 1133 Location: Sarnia, Ontario, Canada
Posted: Mon Jul 21, 2025 10:53 am Post subject: Re: 2.5L runs rough in third gear. Black smoke |
Some good advice here.
Impressive feat getting it running after 2 years. I have found that our current rendering of gasoline with ethanol really deteriorates rapidly, not just the fuel but also all the fuel injection components.
Verify all vacuum hoses are in good order. |
