Is this an adjustable front beam? Theres a bolt in my way on it.
Silverteener
Silverteener is offline
PostPosted: Wed Jun 11, 2025 9:42 am    Post subject: Is this an adjustable front beam? Theres a bolt in my way on it. Reply with quote
Hi all,
I'm in the process of replacing the shift bushing on my 62' and have come into a little problem. In the middle of the front beam there is a bolt connecting the top and bottom and it is blocking the path of the shift rod so I can't get it out to install the new bushing. I'm assuming this is an adjustable beam of sorts. Am I safe to attempt to take the bolt out, if not, are there other options to replace a shift bushing? Any help is greatly appreciated. Thanks!
VeloMikey
VeloMikey is offline
PostPosted: Wed Jun 11, 2025 10:48 am    Post subject: Re: Is this an adjustable front beam? Theres a bolt in my way on it. Reply with quote
That is an old school select-a-drop. It is the precursor to the Sway-A-Way adjusters which make a beam adjustable. The Select-A-Drop was dangerous because the long bolt connecting the adjusters could break and leave you stranded or worse cause an accident. Once the bolt broke, the beam hit the ground.
'58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748
Ian Godfrey
Ian Godfrey is offline
PostPosted: Wed Jun 11, 2025 5:00 pm    Post subject: Re: Is this an adjustable front beam? Theres a bolt in my way on it. Reply with quote
yes, you can take the bolt out but you may have to have the wheels on the ground to get the bolt back in.
Silverteener
PostPosted: Wed Jun 11, 2025 7:30 pm    Post subject: Re: Is this an adjustable front beam? Theres a bolt in my way on it. Reply with quote
Thank you for the info. I loosened the bolt to make a little more room but the shift rod still slightly hits the access hole inside the front trunk. Maybe a 1/4", I think I'm just going to bend the metal back and get it out.
