Sporgle Samba Member
Posted: Thu Jun 12, 2025 9:56 am Post subject: Passenger side headlight not working |
I've got a 69 stock seen some years but overall good condition. I've got a problem with my passenger side headlight not lighting up. I've tested the bulb and it tested good in the driver side.
I did test with a voltmeter on the connector itself there are three wires inside of it a yellow a white and a brown or red but it's faded. All combinations yield the same voltage of around 11.9 to 12 with the engine off and just the battery except for yellow and brown which reads only about .2 volts.
I'm not very familiar with the electronics in this car so I'm kind of stumped is there a wiring issue or maybe a connector is bad is that the correct readouts for those wires? any help greatly appreciated thank you! |
Posted: Thu Jun 12, 2025 10:05 am Post subject: Re: Passenger side headlight not working |
I forgot to mention, when the bulb is in and lights turned on all connectors read 0 volts. But only when the light is plugged in. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35772 Location: Conejo Valley, CA
Posted: Thu Jun 12, 2025 10:11 am Post subject: Re: Passenger side headlight not working |
Check/spin fuses.
Check your wires against this diagram below.
White is high beam, yellow is low beam. Brown is ground. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 802 Location: Moreno Valley
Posted: Thu Jun 12, 2025 10:28 am Post subject: Re: Passenger side headlight not working |
likely the ground connection . in my 70 there in the front trunk by the gas tank , left n right . |
Posted: Thu Jun 12, 2025 10:32 am Post subject: Re: Passenger side headlight not working |
Checked and cleaned ground, checked and cleaned fuses. No dice.
The only electric work I've done is the turn signal switch. Could this cause any issues?
As extra info my low beams have never worked the switch is probably bad or something and the hazard switch is touchy and will cause the turn signals to not function if it isn't screwed in all the way. This car is a little of an electrical nightmare inherited from my grandfather who never replaced only repaired to good enough lol. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16534 Location: North Florida, USA
Posted: Thu Jun 12, 2025 2:19 pm Post subject: Re: Passenger side headlight not working |
When you say the bulb tested good when installed on the driver's side... did you test both HI and LOW beam function?
FYI, HI beam power comes over WHITE wires. LOW beam power is YELLOW wires. If your passenger side headlight plug has 0.2v on the yellow wire and 12v on the white wire it suggests your HIGH beams are ON and not your LOWs. The BROWN wire in the plug is a ground wire.
Power for the headlights comes from the headlight switch over the white/black wire to the headlight dimmer relay. The dimmer relay is a latching relay. This means it "latches" to an output path until the relay is next momentarily powered and then it "latches" to a different output path. This means the relay is powering either its LOW (yellow) wire or HI (white) wire output. Each wire from the dimmer relay should connect to the side of the fuse box where a brass bar is connecting a pair of fuses together. This allows a single wire to power a pair of fuses. The yellow wire from the relay powers fuses #5 & #6. The white wire powers fuses #3 & #4.
Rerun your test:
Turn the Headlight switch ON to the 2nd position (headlights and parking lights ON).
With one probe of your tester grounded to a "known good ground" (ground screw or fuel tank bolt?), test the white and yellow wires at the headlight plug. Only one wire at a time will read 12v.
Go to the wire side of your fuse box in the trunk. Fuses #3~#6 are your headlight fuses (#3 is 3rd from the right edge as viewed from the trunk side of the fuse box). If wired as shown above, fuses #3 & #4 will have white HIGH beam wires. Fuses #5 & #6 will have YELLOW. Test the pair of fuses here at the fuse box. Test both ends of the fuses to confirm power is flowing thru the fuse. Depending which colored wire at the plug was powered, test the corresponding two fuses here connected to the same wire color.
Next, pull on the turn signal lever to activate the dimmer switch. This should cause the dimmer relay to click and change its output.
Go back and test the white and yellow wires at the headlight plug. Power should have switched to the other colored wire. Also test that the pair of fuses for the same color wires are now powered at the fuse box.
This confirms you headlight dimmer switch and relay are working and powering the proper pair of fuses and wiring all the way to the headlight plug.
Lastly, retest for power on the WHITE and YELLOW wires at the headlight plug like you did above, but move the ground connection from the known good ground to the brown wire in the headlight plug. The headlamp itself using this brown wire for its ground. You should get the same voltage reading.
See below Speedy Jim's diagram on headlight wiring. Note how the headlight plug is wired. Confirm your wiring matches this diagram.
Above, you would imagine that the opposing wires would be the power wires and the different wire would be the ground. This is not how the plug is wired. If your plug is incorectly wired you can remove the wires from the plug and reinsert them in the correct position. You may need a small jeweler's screwsdriver to compress the locking clip of the brass terminal to free it and it will pull free from the plug. It helps to bend this clip outward slightly before reinserting it. _________________ AshMan40
Posted: Thu Jun 12, 2025 2:25 pm Post subject: Re: Passenger side headlight not working |
Alrighty I'll give that a shot, I know for sure low beams don't work at all for either side it's a problem it's had for a while I assume due to the switch or relay.
Another person said it could be grounded out somewhere because once the circuit completes when the bulb is in I get no voltage at all on any wire going to the headlight. But I'll give the tests a shot and let you know, thanks! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 32973 Location: Hot Arizona
Posted: Thu Jun 12, 2025 2:37 pm Post subject: Re: Passenger side headlight not working |
Sporgle wrote: |
The only electric work I've done is the turn signal switch. Could this cause any issues? |
Not with the headlights. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jun 12, 2025 3:09 pm Post subject: Re: Passenger side headlight not working |
well , the high / low beam is in the turn signal switch here . so it just might have something to do with it , like if it cant complete cirquit ......does your high low switch do anything ????
lift towards you on the turn signal lever ?
you have to be pretty precise playing with wires . some new modern repo switches the wire codes arent as easy to color code . a few wires were like the wrong color or had no stripe i forget but i figured it out as i just put in one of these switches recently . ya your headlights go thru there ..........
just saying in a 70 the turn signals all run thru the emergency flasher switch , that was fun to figure out . |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11077 Location: Huntington Beach, CA
Posted: Thu Jun 12, 2025 3:16 pm Post subject: Re: Passenger side headlight not working |
X2 with rolling the fuses.
Turn the key on. Turn the headlights on. Then roll the fuses. They will most likely spark a little bit while you roll them in their holders! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
High beams work for driver side and passenger side until passenger side gave out, and the dimmer for the dash light works, bulb is out but I know the dash works. Low beams don't work on either side. |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1001 Location: half a bubble from plumb
Posted: Thu Jun 12, 2025 3:32 pm Post subject: Re: Passenger side headlight not working |
Use a multimeter & check wires for continuity without power.
Jam a piece of paperclip into wire. Run from battery to inside of headlight plug on yellow then white wire. This will bypass switch. Careful with this test as will not tolerate being grounded at anytime.
A few months ago my headlight switch separated from its metal housing. Used a zip tie to get me home. Still functional to this day.
Redneck troubleshooting at its laziest - always think outside the box.
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Thu Jun 12, 2025 11:04 pm Post subject: Re: Passenger side headlight not working |
Sporgle wrote: |
... I know for sure low beams don't work at all for either side it's a problem it's had for a while I assume due to the switch or relay.
...and the dimmer for the dash light works, bulb is out but I know the dash works. Low beams don't work on either side. |
I'm starting to get confused. From your first description I was thinking you tested the passenger side bulb on the driver side and it was fully functional (HI and LOW) but now you are saying the LOW beams never worked? So how can you say it "tested good in the driver side"??
Sounds like you are saying you only had HI beams on both sides (no LOW beams) and recently you lost the passenger HI beam so now only have driver side HI??
Check the S wire on the dimmer relay. This should be a brown or brown/white wire coming from the dimmer switch on the turn signal lever. When the lever is pulled this wire is grounded. Test for this at the dimmer relay end of the wire.
If the wire tests good, use a jumper wire to test the dimmer relay. With the headlights ON, use a jumper wire to momentarily ground the S terminal. The relay should click and the headlights should switch between HI and LOW beams. Ground it again and the relay should switch back.
Do you have a 4-prong or 5-prong dimmer relay? 5-prong relays will have an extra #30 terminal that MUST be powered with 12v for the relay to work.
Many dimmer relays will hold the HI beams ON while the S terminal is grounded. This means if the dimmer switch at the turn signal lever is stuck ON it will force the dimmer relay to keep the HI beams ON all the time and will lead to burning up the dimmer relay. It is not meant to be continuously energized.
Look at the inner end of the turn signal lever and you will see two brass contacts that should have an air gap. When you pull the lever the contacts are closed. These contacts can get stuck together. Working them with a screwdriver can get them to stay apart. _________________ AshMan40
Cusser Samba Member
Posted: Fri Jun 13, 2025 7:12 am Post subject: Re: Passenger side headlight not working |
Electrical stuff is tough to "fix" long distance.
For someone like Ashman, myself, or many others on this forum, this would be under 15 minutes to diagnose if we were with the vehicle. Bring it to Arizona, The Cuss will fix ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
