buspeople Samba Member
Posted: Fri Jun 13, 2025 12:30 pm Post subject: 009 suspect or not? |
Does this look like an issue to anyone? Engine has been running fine however, I came across this while doing a valve adjustment. After the valve adjustment it seemed like it was running a little hot and upon inspection came across this..
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7453 Location: Houston, Texas
Posted: Fri Jun 13, 2025 3:31 pm Post subject: Re: 009 suspect or not? |
That's bad. Without that shimmed up what happens is the shaft can move up and down and then side to side later on. Get some shims and replacement fiber washers and you might be good to go. _________________ www.vwnos.com [email protected]
Posted: Sat Jun 14, 2025 5:00 am Post subject: Re: 009 suspect or not? |
Kinda what I figured lol.. I had a spare 009 on the shelf that I went ahead and replaced this one with. Pretty sure this is an original Bosch unit so definitely worth getting restored. Thanks again for the input! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79378 Location: Sneaking up behind you
Posted: Sat Jun 14, 2025 5:16 am Post subject: Re: 009 suspect or not? |
buspeople wrote: |
Don't waste you money, just get a better distributor. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
heimlich  VWNOS.com
Posted: Sat Jun 14, 2025 5:34 am Post subject: Re: 009 suspect or not? |
buspeople wrote: |
Original Bosch is good. Most likely you will need to remove the plate that points sits on in the top of the distributor. After you do that remove the pin and gear on the bottom. Pull the shaft out. You'll want to replace the inside fiber washer if it is there. If it is not then it has disintegrated. Slide the shaft back in and put a fiber washer on the bottom and then reshim it. Reattach the pin and you are good to go. There might be other issues with the distributor but that process above will fix your current issue. Make sure when you buy the washers you buy the fiber kind. There are a lot of paper ones out there people are selling and using which do not work. They also need to have the dimples in them to hold the oil. _________________ www.vwnos.com [email protected]
Posted: Sat Jun 14, 2025 6:00 am Post subject: Re: 009 suspect or not? |
Glenn wrote: |
buspeople wrote: |
Don't waste you money, just get a better distributor. |
Funny you say that, the more reading I do on the subject that seems to be the general consensus lol. Seems they’re fine in a pinch but..
This is in an original HO 15/1600 single port, H30/31 carb, any suggestions on what to use in place of 009? Did my engine originally come with dual vacuum distributor? Again, thanks! Learn something new everyday.. |
Glenn  Mr. 010
Posted: Sat Jun 14, 2025 6:32 am Post subject: Re: 009 suspect or not? |
buspeople wrote: |
The H30/31PICT is not the original carb, it's an aftermarket replacement also,
If I remember correctly, the 113-905-205T distributor, which is vacuum only, work well with that carb. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Posted: Sat Jun 14, 2025 7:21 am Post subject: Re: 009 suspect or not? |
Glenn wrote: |
buspeople wrote: |
If I remember correctly, the 113-905-205T distributor, which is vacuum only, work well with that carb. |
Good to know..guess when I was told it was all original, they must have meant the case only lol..thanks for all the helpful insight. |
chiroracer Samba Member
Joined: August 03, 2006 Posts: 344 Location: long beach
Posted: Sat Jun 14, 2025 8:52 am Post subject: Re: 009 suspect or not? |
FWIW , I got a bus a few months ago with a common 1600DP it has a 30/31 pict bras. carb and an import from wherever 009 and it runs SWEET after just cleaning the mouse nests out of the heads and fan housing. _________________ 66 bajawestfalia
2/1600 buggy Kreger chassis 4 baja 1000(waiting to re emerge)
71 911 track car
65 kombi EZ camper (sold to OG owner in oregon)
69 class 11 racecar Sold to GH racing now the famous Dora SCOREchampion
70 class 11 prerunner |
tasb  The Distributor Distributor
Joined: April 27, 2002 Posts: 6707 Location: Pentwater, Michigan
Posted: Sat Jun 14, 2025 12:48 pm Post subject: Re: 009 suspect or not? |
You will be looking for a SVA distributor. Besides the 113 T you could also run a 113 M or 113 K distributor with that carburetor. That will restore smoother running and a little better mpg. A properly shimmed 009 is a good back up if you are a worrier. _________________ Roads Scholar
Member# 2059 |
