phil60 Samba Member
Posted: Sun Jun 15, 2025 11:16 am Post subject: Fan belt problem |
Hi - I'm having trouble fitting a new fan belt to my car - 1959 30hp. The belt I bought is 9.5 x 905mm which is listed as being suitable. However it is shorter than the belt currently fitted. I understand the principle to fitting the belt and have managed to do it but only by using all 11 shims that I have and even then it is very tight with no give at all. Anyone else had this problem? I have found a belt by Optibelt which is 9.6 x 912mm may be that would be suitable? |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1407 Location: San Diego
Posted: Sun Jun 15, 2025 12:40 pm Post subject: Re: Fan belt problem |
Do you still have the old belt that fit properly? If so, compare it to the new one to see how much longer it is and use that to guide you to a better fitting size. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 854 Location: Moreno Valley
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1021 Location: South Florida
Posted: Sun Jun 15, 2025 2:17 pm Post subject: Re: Fan belt problem |
So, 900mm is supposed to be the right size. But, 905 is too small? We have a contradiction! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Sun Jun 15, 2025 7:04 pm Post subject: Re: Fan belt problem |
You're running into belt size problems because you have a 40hp generator pulley on your 36hp engine. The correct 36hp generator pulley is smaller diameter. _________________ 1960 Ragtop w/Semaphores "Inga" |
phil60 Samba Member
Posted: Mon Jun 16, 2025 1:23 am Post subject: Re: Fan belt problem |
Oh OK thanks - very strange. I will just have to try and get a slightly longer belt. |
