Questions about Fuel tank options for 1972
poundman
poundman is offline
PostPosted: Mon Jun 16, 2025 7:50 am    Post subject: Questions about Fuel tank options for 1972 Reply with quote
I am faced with replacing my 1972 fuel tank. It is way beyond repair. My questions and dilemma.
This tank is unique for 72 and part of 73.
My options are:
1. Retro fit 68-71 tank (new or used).
2. Buy used 72 tank (I have found no new tanks)
3. Retro fit a 73-74 (new or used).
My big question is, are the barrel type sending units better than the float style that started in 73? That might sway my decision. Why did they switch?
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jun 16, 2025 9:54 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
having owned both sender types (1971 & 1977), they are both unreliable compared to most cars today. To my knowledge, it is impossible to get an accurate late sender reproduction that will work without some kind of electronic interface. I recently had a spare NOS late VDO one on the workbench with a NOS late gauge, and a late NOS voltage regulator, along with a regulated power supply set up to 13.8V. While I could adjust the sender so that it worked full sweep from empty to full, it will not agree with the marks. The issue being for me that if I was relying on it then each time I tank up on a trip I have less range. My MDX has almost a 500 mile range. The bus is about 250 miles. Shorten it by leaving a lot of gas in the tank, and one is making more stops than needed and losing time on a long trip. On the flip side, there is less chance of running out, but it is stressful looking at a gauge reading low when the next station is 100 miles away. That is especially true in the west on less congested highways. I never had that issue with the 1971, and in 750,000 miles (and about 5 or 6 senders) only ran out of gas once.
poundman
poundman is offline
PostPosted: Mon Jun 16, 2025 10:11 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
Sounds like the lesser of evils is the older barrel type then?
Sugar Land, Texas
SGKent is offline
PostPosted: Mon Jun 16, 2025 12:04 pm    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
you will be replacing or repairing senders regardless which you use. There is a myth that fixing the conenctions on an early sender will solve the problem for ever. I found two kinds of failures on early senders - corrosion interferes with the connections on top, which cleaning and soldering will solve, and the float fingers stop making good contact with the wires. There are quite a few old used early senders available still, that can be repaired. The late ones delaminate when they go bad. The early and late sender require different gauges so if you already have a working early gauge, go with the type sender type you have now. They work together.
CTSkim
CTSkim is offline
PostPosted: Thu Jun 19, 2025 5:08 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
I just went thru this a few years ago, what I ended up doing was to cut the threaded fuel outlet and the sender hole out of my 72 tank with a 2 or 3" hole saw.... I used a wood dowel chucked up in the hole saw to center myself.... I took said pieces and the new unused 73 up tank and had a buddy cut and tig weld them into the new tank...
the early 68-71 tank didn't come close to fitting in my 72 so I don't believe that is an option and as SGKent said you would need a new gauge at the dash if you go with the later sender....
I did repair my sender as there was some corroded connections. But I believe if you dig deep here there was a post about that as well as what wire to purchase if the thin wire is gone in your sender
Project 67 Beetle
72 Sierra Yellow Westy
82 Tin Top Vanagon
wagen19
wagen19 is offline
PostPosted: Thu Jun 19, 2025 5:21 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
It seems, not only in Germany, there are correct 72 repro fuel tanks available.
(I have nothing to do with the seller and have no info about quality)
Why not a search with parts number?
https://www.google.com/search?client=firefox-b-d&q=211+201+075+H+in+USA
https://www.csp-shop.de/auspuff-heizung/kraftstoff...UwJGwwJGgw
https://www.csp-shop.de/auspuff-heizung/tank-201-0...QzJGwwJGgw
poundman
poundman is offline
PostPosted: Thu Jun 19, 2025 6:25 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
Thanks Wagen19. It does appear that in EU there are exact replica tanks, however in the US it appears most replacements are hybrid models that will also fit for 73-74 with the float type sender. CIP1 seems to be the very close replica., they use the part number 211-201-075-H but description says it is for 68-71
I will check out the links in more detail
Sugar Land, Texas
SGKent is offline
PostPosted: Thu Jun 19, 2025 7:18 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
you will need to change the gauge if you change the sender type
poundman
poundman is offline
PostPosted: Thu Jun 19, 2025 9:19 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
Frustrating: CIP1 lists has listed
VWC-211-201-075-H listed as 68-71 but it looks exactly like the 72-73 tank. That is the wrong part number for 68-71.
https://www2.cip1.com/vwc-211-201-075-h/
C24-211-201-075-H - listed as 73-79, but again that is the wrong part number. That one looks like it has 3 vents on top but sender might be screw on type. But it does mention threaded output.
https://www2.cip1.com/c24-211-201-075-h/
I have asked them to send me pictures of the actual part VWC-211-201-075-H. I am pretty sure something wrong on this listing, I assume it is 72-73 part based on the pictures. Let's see.
Sugar Land, Texas
SGKent is offline
PostPosted: Thu Jun 19, 2025 9:25 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
BusDaddy gave you the solution if you want to use the 1968-71 tank. I also sent you links to a 1972 tank. You can also check with TheBusCo and BustedBus for an original 1972 tank. Nothing else to add here, other than you cannot change the sender type unless you change the gauge type too. It is more than just the mounting, they work on completely different technologies and resistances.
poundman
poundman is offline
PostPosted: Thu Jun 19, 2025 9:54 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
Thanks, I am waiting for shipping cost on the used tanks listed. I did check with thebusco also, he did not have any I see used tank as always a risk of hole like my original.
Looks like bustedbus has 1 also I will consider.
Sugar Land, Texas
SGKent is offline
PostPosted: Thu Jun 19, 2025 1:43 pm    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
both sellers are known for being good here.
wagen19
wagen19 is offline
PostPosted: Sat Jun 21, 2025 3:27 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
Used tanks:
Why are there no pics of the inside of tanks? Endoscope, camera?
Old scool method for poor people: take the sender out and look in! Click then!
What happens when pressured air is blown in? What comes out then?
poundman
poundman is offline
PostPosted: Thu Jul 10, 2025 7:49 am    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
I finally order a used tank from Bustedbus. CIP1 would never send me pictures to confirm if there part was correct, even though I told them description and part number did not match.
Sugar Land, Texas
mikedjames
mikedjames is offline
PostPosted: Thu Jul 10, 2025 1:00 pm    Post subject: Re: Questions about Fuel tank options for 1972 Reply with quote
I recently purchased a later style lever sender from a supplier who sells the BBT sender unit and it has what looks like a correctly constructed resistor track for the later style hot wire gauge.
I do not like a gauge that reads full for 10 miles, drops rapidly to 1/4 full and is on the warning red section for about 110 miles ..
Although it is not an "open plan" sender you can see inside :
looking inside the sender .
box
It cost £40 + shipping over here in the UK from Alan Schofields.
As I have a fuel sender hatch on my tank, I will try and swap it this weekend after I have taken my bus on a 60 mile trip so the tank will not be too full.
Ancient vehicles and vessels
