Got my engine all tuned and running great
liquidrush
liquidrush is offline
PostPosted: Mon Jun 16, 2025 2:19 pm    Post subject: Got my engine all tuned and running great Reply with quote
And no oil leaks. I had a carb issue that was traced to a partially plugged idle jet but aside from that it runs great, makes a ton of power and it's driveability is excellent. I'm quite happy with it. You can see I painted my vacuum advance pod and throttle arms candy apple red.
busdaddy
busdaddy is offline
PostPosted: Mon Jun 16, 2025 3:21 pm    Post subject: Re: Got my engine all tuned and running great Reply with quote
Congratulations!, and thanks for posting something positive that didn't ask why it was broken! Cool
Слава Україні!
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Tue Jul 01, 2025 9:29 am    Post subject: Re: Got my engine all tuned and running great Reply with quote
How do you like that coil? I just got one need to build a new wire for the different male coil end. Going to keep two wire incase it fails and have to switch back over.
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
zerotofifty
zerotofifty is offline
PostPosted: Tue Jul 01, 2025 9:59 am    Post subject: Re: Got my engine all tuned and running great Reply with quote
Nice!!! Let's see the rest of your rig now.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
