Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Tue Jun 17, 2025 8:27 am Post subject: For all you Small Block Chevy guys.. |
My sister-in-law inherited a 1960 Biscayne from her dad when he passed last year. The car was a mess, hacked together wiring, incorrectly setup brakes, rust issues in the floor, etc. It was originally a 6 cylinder 3 on the tree car, it is now has a Turbo 350 and a 350.
The car always overheated, it had the stock 6 cylinder radiator with no shroud, a hacked in aftermarket mechanical fan, leaking water pump, no thermostat, etc.
I believe the engine is a stock internal 350, only it has 305 heads, a performer RPM intake, headers, an aftermarket 4 barrel, and an MSD ignition setup.
I have installed a new 180 thermostat, new aluminum 2 core radiator, new water pump, fan shroud, and a new correctly fitting aftermarket fan. The fan has had the spacing setup to be half in/half out of the shroud. Timing is set at 14 idle, 36 at RPM.
I did put a Vintage Air AC setup on it, so there is a condenser in front of the rad now.
As long as the car is moving (even at slow speeds), the temp will sit about 185-190 max on the gauge, (180 at highway speeds), but as soon as it gets heat soaked it will start creeping up when parked. Temps could creep up to 210-215 in a few minutes.
Other than adding an electric pusher fan in front of the condenser, or just going full electric with a thermostat switch on the rad, any other ideas of what I can try? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11081 Location: Oregon
Posted: Tue Jun 17, 2025 10:43 am Post subject: Re: For all you Small Block Chevy guys.. |
It should be fine at the traffic temps you posted.
How hot does it get?
It it were to hit 240°F, that would be cause for concern.
The heat soak can be combatted by turning on the AC.
Doing so should make the condenser fan come on and stay on to assist cooling the engine.
That is, if, there is an electric fan controlled by the AC. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2883 Location: HdG, MD & NJ
Posted: Tue Jun 17, 2025 2:52 pm Post subject: Re: For all you Small Block Chevy guys.. |
Sometime sbc parts get mix matched and 400 parts and or wrong head gaskets. Probably not your issue. Just thought I’d throw it out there.
Air bubble in the system?
And, I think lately, guys are using pusher only electric fans. The more cfm, the better. Try Water wetter additive. It does work. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Tue Jun 17, 2025 5:50 pm Post subject: Re: For all you Small Block Chevy guys.. |
67rustavenger wrote: |
That is, if, there is an electric fan controlled by the AC. |
Nope, no fan on this system. It just relies on the air flowing over the rad while driving/engine driven fan pulling air through it.
Previously it would creep up close to 250 pretty fast, but I ran it with no rad cap for a while, then cracked the heater return hose from the new heater core. Got a big bubble out of the rad, and a bunch of air from the heater core. Just a symptom of having the whole system drained to do the work/vintage air system install. |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11161 Location: Huntington Beach, CA
Posted: Tue Jun 17, 2025 6:55 pm Post subject: Re: For all you Small Block Chevy guys.. |
Maybe a 3 or even a 4 row radiator. That would be my first try. _________________ Jimbo
TDCTDI wrote: |
GFY's Xevin and VW_Jimbo!  |
FarmerBill  Samba Member
Joined: July 25, 2017 Posts: 865 Location: New England
Posted: Wed Jun 18, 2025 6:59 am Post subject: Re: For all you Small Block Chevy guys.. |
Bashr52 wrote: |
Make sure you have the correct cap on your radiator and that its still functioning. I had an overheating issue on an International C60 engine a few years back, replaced the cap, back to normal. Also, the 1960 Biscayne is in my opinion, one of the best looking American cars ever. |
RUNKLE Samba Member
Posted: Wed Jun 18, 2025 8:20 am Post subject: Re: For all you Small Block Chevy guys.. |
First thing you need to do is to check your temperature gauge to make sure it is operating correctly. The optimal operating range for a stock 350 should be between 185 and 220... 230 is considered overheating.
Part of your overheating problem is the 305 heads - they increase compression and have mismatched water jackets and overall low performance due to their small valves. Replace them with the correct 350 heads.
Radiator, like Jimbo said, replace it with a three or four row. I would go with a four row core, but that’s just me.
160 to 180 thermostat - your thermostat is fine.
DO NOT turn on the AC, doing so adds a load to an already overheating engine and will increase the temperature. This sounds counterintuitive but turning on the heater however will increase the flow of coolant and will aid in temp control.
. _________________ Type 1
Type 3
1968 Squareback |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13546 Location: Tejas!
Posted: Wed Jun 18, 2025 10:57 am Post subject: Re: For all you Small Block Chevy guys.. |
215 is ok 220 is getting too hot
Make sure the radiator is butted up against the header panel. A lot of guys use the wrong radiator and it leaves a gap there. Air needs to flow through it not over it.
Aftermarket fan? like a flex fan? I've always heard the stock fan stock stock shroud was preferable for AC cars. The vintage air conversions really do add some heat in my experience |
Joined: January 01, 2007 Posts: 17842 Location: sticksville, ct.
Posted: Wed Jun 18, 2025 3:25 pm Post subject: Re: For all you Small Block Chevy guys.. |
SBC's usually run around 220* and 230 is considered the start of them overheating
how long does it take at idle to hit those temps?
this thing may be compromised had it been consistently running too hot. your cooling system may be a hair too small as well. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
64 ragtop volks Samba Member
Posted: Wed Jun 18, 2025 8:23 pm Post subject: Re: For all you Small Block Chevy guys.. |
you could try using some redline water wetter to help drop temps |
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 227 Location: Grand Junction, CO
Posted: Wed Jun 18, 2025 10:14 pm Post subject: Re: For all you Small Block Chevy guys.. |
Chevy talk.org
Those heads....not a good idea....as mentioned and for the reasons mentioned.
The chambers, on the heads, are an issue.
Do I understand you to say....no cooling fan at all. If so, that is an issue. |
Dusty1 Samba Member
Posted: Sat Jun 21, 2025 6:41 am Post subject: Re: For all you Small Block Chevy guys.. |
Bashr52 wrote: |
I have installed a new 180 thermostat, new aluminum 2 core radiator, new water pump, fan shroud, and a new correctly fitting aftermarket fan. The fan has had the spacing setup to be half in/half out of the shroud. Timing is set at 14 idle, 36 at RPM. |
Whenever I buy a radiator I buy the thickest one I can get. If there is a big block air conditioning specification that's the tone I want. The thermostat will get it to temperature. The big fat radiator will keep it there.
There are any number of electric fan arrangements both OEM available at the junkyard and aftermarket available from Jeg's, Speedway etc.. Natural airflow stops, fan(s) kick on. That's how modern vehicles designed to wade through traffic are designed. |
