liquidrush Samba Member
Posted: Sat Jul 12, 2025 4:38 pm Post subject: Bowden tube mounting |
What are you guys doing for Bowden tube mounting in a tube frame car? I can plug it in to the transmission hole on the front but I have nothing for the other end. |
BFB Samba Member
Posted: Sat Jul 12, 2025 5:20 pm Post subject: Re: Bowden tube mounting |
Ive had / run a couple that didnt have the front of the tube mounted. Even like that it was better than no tube at all _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Schepp Samba Member
Posted: Sat Jul 12, 2025 9:39 pm Post subject: Re: Bowden tube mounting |
Find a spot on the chassis that you can mimic the “bow”. Then fabricate your own. A piece of tubing that the Bowden Tube fits will work. Then weld it in place.
On a lot of tube chassis cars, everything is custom or handmade. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20834 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jul 13, 2025 7:44 am Post subject: Re: Bowden tube mounting |
Tube frame cars are fabrication projects..... Fabricat what you need.... _________________ “Fear The Government That Wants To Take Your Guns"
cbeck Samba Member
Joined: January 14, 2014 Posts: 2571 Location: high ridge, mo
Posted: Sun Jul 13, 2025 8:27 am Post subject: Re: Bowden tube mounting |
You running solid mounts or something else? Never had a need, even my baja's had solid mounts and straps. The only thing moving then is my foot on the pedal. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Sun Jul 13, 2025 11:19 am Post subject: Re: Bowden tube mounting |
I figured I'd have to make something, I was just wondering what everyone else came up with is all. I'm running rubber mounts that have maybe an hour of running time on them. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1032 Location: South Florida
Posted: Sun Jul 13, 2025 1:05 pm Post subject: Re: Bowden tube mounting |
I cobbled the forward end of my bowden tube, using 4 hose clamps around a couple small roll'd up pieces of sheet metal:
Check out this far more elegant adjustable solution:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8018955 |
BFB Samba Member
Posted: Sun Jul 13, 2025 3:46 pm Post subject: Re: Bowden tube mounting |
ive run several with and without the Bowden tube and if I can, I'll run one. not that you have to have it but it does add a nice " spring" to the cable, it helps give it a little slack while also keeping tension on it. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
WaterBuggy_24 Samba Member
Posted: Sun Jul 13, 2025 6:17 pm Post subject: Re: Bowden tube mounting |
I had some left over evil energy braided fuel/oil tubing. It's got a Teflon tube running down the inside so the cable slides through it easy. I run it from the pedal to the fan shroud where I've got an aluminum tube with a little pulley wheel on it. Works good. Still need to trim it yet. _________________ One day, I may learn.
Probably not today though. |
Posted: Sun Jul 13, 2025 6:22 pm Post subject: Re: Bowden tube mounting |
Here are photos to my previous reply.
oprn Samba Member
Joined: November 13, 2016 Posts: 14868 Location: Western Canada
Posted: Mon Jul 14, 2025 3:10 am Post subject: Re: Bowden tube mounting |
I made this out of a small aluminum bar. It bolts on with the front most crankcase half bolt. Without it the throttle was so hair trigger I looked like a woodpecker trying to drive at slow speeds! That is with solid engine mounts.
_________________ Our cars get old, we get old but driving an old VW never gets old! |
Schepp Samba Member
Posted: Mon Jul 14, 2025 6:28 am Post subject: Re: Bowden tube mounting |
On my friends Towd he ran copper tube down the center of the chassis and welded a steel seatbelt clip from an old harness to the torsion tube. The hole in the clip was ironically the perfect fit for the copper and Bowden-tube union. It didn't look great but worked perfectly. |
Posted: Mon Jul 14, 2025 11:31 am Post subject: Re: Bowden tube mounting |
Well I hand plasma cut some 1/4" plate I had laying around and made a holder for the back of the tube, it's heavy duty AF but it's all I had. Initially the tube had way too much bend so I whacked it down until I liked it. Works perfectly and my clutch is smoother than ever.
Schepp Samba Member
Posted: Mon Jul 14, 2025 1:03 pm Post subject: Re: Bowden tube mounting |
Good job dude! |
