Front turn signal bulb connection
toddhegstrom
toddhegstrom is offline
PostPosted: Mon Jun 23, 2025 12:39 pm    Post subject: Front turn signal bulb connection Reply with quote
Both my bulb holders 63 ghia have no contacts for the bulb contacts to sit against. Previous owner had soldered wires directly to the two bulb contact (dual filament ). Cant see how the wires were connected to the bulb holder. Is that connection piece I can find. ?Any ideas ?
22manybugs
22manybugs is offline
PostPosted: Mon Jun 23, 2025 4:17 pm    Post subject: Re: Front turn signal bulb connection Reply with quote
Never seen that before. Pretty ingenious/desperate!
This might be what you need: https://www.mtmfg.com/part/view/lenses-and-seals-f...amp;src=96
Looks like it is supposed to attach where the nubs are next to the bulb. Are those screw heads? I can't tell. You may have to drill out the nub and tap a thread to screw in the contact unit.
Lon
1969 Karmann Ghia convertible
1971 Westfalia camper
