Solex 32 pbic float setting?
mcdragracer
mcdragracer is offline
PostPosted: Tue Jun 24, 2025 6:52 am    Post subject: Solex 32 pbic float setting? Reply with quote
I'm finally finishing up the restoration on a dual set of 32 pbic carburetors, wondering if anybody has some information on how to properly set the float level and what the measurement number is, much appreciated!
RUNKLE
RUNKLE is offline
PostPosted: Thu Jun 26, 2025 8:42 am    Post subject: Re: Solex 32 pbic float setting? Reply with quote
19mm from the top mating surface of the carb body to the flat surface of the petrol/fuel/gasoline, otherwise known as the meniscus.
How to properly set the fuel level - increase/decrease the thickness of the gasket to the float needle valve, or by adding/subtracting gaskets. The float toggle lever can be bent to adjust for the level of fuel as well. Pre fuel level check prep - atypical Solex protocol.
Type 1
Type 3
1968 Squareback
mcdragracer
PostPosted: Thu Jun 26, 2025 9:05 pm    Post subject: Re: Solex 32 pbic float setting? Reply with quote
Thanks for the info!
