Pushrods on single High Rev
xFontix039
xFontix039 is offline
PostPosted: Tue Jul 01, 2025 6:06 pm    Post subject: Pushrods on single High Rev Reply with quote
Hello everyone,
I would like to know if anyone use single high rev springs with OEM pushrods. Some say they can handle it and other say they are too weak. The car aint a racer so i dont expect to run over 5000 RPM with it.
Engine specs:
1600cc stock
Engle W100
Rocker: 1.1:1
Engle Lifters
Single high rev springs
Original pushrods
Teeroy Premium Member
Teeroy is offline
PostPosted: Tue Jul 01, 2025 6:10 pm    Post subject: Re: Pushrods on single High Rev Reply with quote
I've used stock pushrods on heavy duty single springs on several engines over the years, never had a problem, just make sure the length/geometry is right. Bolt together rockers as well
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
BFB
BFB is offline
PostPosted: Tue Jul 01, 2025 7:13 pm    Post subject: Re: Pushrods on single High Rev Reply with quote
X’s 2.
Also, some ppl can break an anvil in a sand box so theres also that.
Most experts aren't.
jim martin
jim martin is offline
PostPosted: Tue Jul 01, 2025 7:39 pm    Post subject: Re: Pushrods on single High Rev Reply with quote
im so not hip to this type of valve train anymore.
when you guys are talking this aluminum and single spring setup post up some details so I can get in the know.
valve diameter. installed height .spring data , lift and duration at cam , lift at valve , lifter weight. pushrod length and wall ,max rpm .
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Tue Jul 01, 2025 8:21 pm    Post subject: Re: Pushrods on single High Rev Reply with quote
Work fine for me
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
