CoastalBug Samba Member
Posted: Thu Jun 26, 2025 10:39 pm Post subject: Flooded engine after trailering? |
Drove 5 hours to pick up my beetle today. Started right up when I got there. Put her on a U-Haul auto transport trailer and drove 5 hours home. Couldn’t get her started to back her off the trailer, and it smelled of gas really bad. I’m letting her sit overnight, but could the bouncing around on the trailer flood it like that? |
DesertSasquatchXploration Samba Member
Posted: Thu Jun 26, 2025 11:58 pm Post subject: Re: Flooded engine after trailering? |
Yes it can happen. I flat tow my Baja it happened a few times over rough washboard roads. I use a harborfreight clamp during transport. If you have a full tank its worse.
https://www.harborfreight.com/4-piece-fluid-line-clamp-set-65116.html _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3300 Location: Hamble, Hampshire, UK
Posted: Fri Jun 27, 2025 4:49 am Post subject: Re: Flooded engine after trailering? |
Prohably worth checking the oil for fuel contamination as well. _________________ Ancient vehicles and vessels
Posted: Fri Jun 27, 2025 8:13 am Post subject: Re: Flooded engine after trailering? |
Couldn’t get it going again this morning. And smelled gas again. I’m wondering if the carb float got knocked around and is stuck. |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 472 Location: South Bay LA, California
Posted: Fri Jun 27, 2025 8:24 am Post subject: Re: Flooded engine after trailering? |
Easy enough to check.
Also check and see if you’ve fuel fouled the plugs, if they’re wet you should be able to clean them up.
After you get the fuel level in the bowl sorted, you may have to hold the throttle WFO to get it to start. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20797 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jun 27, 2025 12:29 pm Post subject: Re: Flooded engine after trailering? |
IF you find out engine flooded and you plan to trailer often, maybe fuel shut off valve is in order... _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Fri Jun 27, 2025 1:13 pm Post subject: Re: Flooded engine after trailering? |
GOT IT! Took the carb cover off and bounced the float (bowl was FULL of fuel), took the oil pain air cleaner thing off, and opened up the choke. Away she went!! Had a little smoke originally (valve cover leak on drivers side) but I drove her around the complex for a few mins and she started right back up again after shutting her off! |
Posted: Fri Jun 27, 2025 5:13 pm Post subject: Re: Flooded engine after trailering? |
Dale M. wrote: |
IF you find out engine flooded and you plan to trailer often, maybe fuel shut off valve is in order... |
I only trailered it to get it home. I'm hoping to make it a DD.
But the victory was only short lived. It flooded again when I tried to start it this evening. |
Posted: Sat Jun 28, 2025 7:11 am Post subject: Re: Flooded engine after trailering? |
CoastalBug wrote: |
Dale M. wrote: |
Carb problem! _________________ “Fear The Government That Wants To Take Your Guns"
oprn Samba Member
Joined: November 13, 2016 Posts: 14697 Location: Western Canada
Posted: Sat Jun 28, 2025 2:17 pm Post subject: Re: Flooded engine after trailering? |
Flooding while on a trailer makes no sense to me. The fuel pump is not running and there is only so much fuel in the float bowl that can possibly splash out no matter how rough the road. The only other way it could happen is if the fuel tank vent is plugged and you have a big weather change, for instance if you were travelling from 45* weather to 90* weather in a very short time.
I have trailered all kinds of vehicles over the years and never had an issue. Cars and trucks get towed and trailered all the time, ask a tow truck driver if he has had it happen. I would put money on him looking at you as if you were from Mars!
I think there has to be some other problem. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 224 Location: Grand Junction, CO
Posted: Sat Jun 28, 2025 2:48 pm Post subject: Re: Flooded engine after trailering? |
I had a dif set-up....but, I had a sandrail and the tank was higher than the carb. I put a ball-valve on my tank and it solved the problem.
Actually, the fuel level was only higher when full. |
liquidrush Samba Member
Posted: Sat Jun 28, 2025 4:42 pm Post subject: Re: Flooded engine after trailering? |
You can also shut off the fuel and run it till there's no fuel left in the bowl. |
Posted: Sat Jun 28, 2025 5:47 pm Post subject: Re: Flooded engine after trailering? |
oprn wrote: |
Flooding while on a trailer makes no sense to me. The fuel pump is not running and there is only so much fuel in the float bowl that can possibly splash out no matter how rough the road. |
You're right, and I believe I just learned that *I* probably flooded my engine. When we got home, first thing I did to try and start it was pump the accelerator a bunch of times. And because my choke may be out of adjustment, it went to full closed. Of course the engine still didn't start, so I tried pumping it some more.
Now that I started my my other thread, everything is starting to make sense. |
