bnam Samba Member
Joined: July 02, 2006 Posts: 3461 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Jun 26, 2025 7:45 am Post subject: 1300 vs 1600 cranks |
While the stroke was the same for 1600, 1500, and 1300cc engines, were the cranks exactly the same?
Shouldn’t the 1600 crank be weighted differently than a 1300 to account for the higher reciprocating masses of the pistons?[/b] _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2177 Location: Gardnerville, NV
Posted: Thu Jun 26, 2025 8:06 am Post subject: Re: 1300 vs 1600 cranks |
it has always been my understanding that the crank, flywheel and clutch are balanced together. since the weight of the rods, pistons, rings, wrist pins etc are directly opposite of one another in the engine it is key to get those as closely matched in pairs as possible. 1&3 and 2&4 respectively so they cancel one another out. meaning as long as those are balanced to one another , it should have no appreciable influence on the balance of the crank.
if someone has a better explanation or can correct me be my guest. _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
oprn Samba Member
Joined: November 13, 2016 Posts: 14769 Location: Western Canada
Posted: Thu Jun 26, 2025 12:56 pm Post subject: Re: 1300 vs 1600 cranks |
bnam wrote: |
While the stroke was the same for 1600, 1500, and 1300cc engines, where the cranks exactly the same? |
There are slight differences in the oil hole drillings. The newer ones have a sort of elongated slot on the surface of the journals. There may be other minor differences too.
bnam wrote: |
Shouldn’t the 1600 crank be weighted differently than a 1300 to account for the higher reciprocating masses of the pistons?[/b] |
The stock cranks did not have counterweights therefore there would be nothing to change when changing displacement. VW counted on the opposing pistons and rods to cancel each other's weight out. Which they do.. sort of... _________________ Our cars get old, we get old but driving an old VW never gets old! |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 343 Location: Eastern north carolina
Posted: Sun Jun 29, 2025 7:37 am Post subject: Re: 1300 vs 1600 cranks |
The 1300 crank was made to accept the 6 volt flywheel. So if my memory serves me correctly you could not bolt a 12 volt flywheel to it. |
