Clutch cable length for'65 Frankenbug, all 9are too short
2type2
2type2 is offline
PostPosted: Sun Jun 29, 2025 12:48 pm    Post subject: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
So my 65 body is on a later chassis, has irs and ball joint beam.( year unknown) The clutch pedal freeplay is about 3" . There is no room left to lengthen cable at the nut.
Given there is only .433 inch/11mm difference between the 54-71,74-79 :2270mm and the 72-74: 2281mm cables -----dont I need more length than that to get to 3/4- 1" pedal play?
At final stages on resto, have not driven bug yet except initially off trailer to shop.Had slight clutch chatter in first getting going. New clutch and plate have been installed. It has 2270 mm cable.
Unless im going nuts, which ain't impossible at my age, what I just read in Bentley is there should be 2mm of free space at nut at the arm when adjusted. What's next step?thanx [/code]
"A life of peace and happiness depends on your own gratefulness"
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jun 29, 2025 1:06 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
Are you trying to say that you can not tighten the nut anymore??????
In Stereo, Where Available!
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Sun Jun 29, 2025 1:29 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
Clutch cable Bowden tube in place w proper bow? Clutch cable tube in tunnel intact and tight?
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
2type2
2type2 is offline
PostPosted: Sun Jun 29, 2025 1:33 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
I think I got it reversed -- but if I tighten the cable to take up slack there will be no space of 2mm--- like Bently says. I'm at the point where I find it important to review a procedure in the book(s) before proceeding ---- but I'm easily put off track. My brain says tighten it but why does Bently say leave space loose? You can't have slack if you take up the space.
My fault for being too literal, but really getting confused too soon.
2type2
2type2 is offline
PostPosted: Sun Jun 29, 2025 1:36 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
When I replaced the fuel line in tunnel, clutch tube was OK- and current bowden is correctly bent.
rcooled
rcooled is offline
PostPosted: Sun Jun 29, 2025 4:18 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
2type2 wrote:
There is no room left to lengthen cable at the nut...dont I need more length than that to get to 3/4- 1" pedal play?
Are you saying that the adjusting nut will come off the cable if it's loosened any more, or that it's at the start of the threaded portion of the cable and can't be tightened any more?
If the former is true, just turn the adjusting nut clockwise to take up the free play at the pedal. If the latter is true, and you still have 3" of free play at the pedal, you need a shorter cable.
Five different lengths of clutch cable are available for the Type 1 chassis > Clutch cables
Check the VIN on your pan (located on the frame tunnel near the shift coupler access plate) to see what year it is, then get the right cable for it.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
zerotofifty
zerotofifty is offline
PostPosted: Sun Jun 29, 2025 7:21 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
To reduce the pedal freeplay, you need to in effect shorten the cab,e by moving the cab,e adjusting nut towards the clutch arm, i.e. turn the nut so nut travels closer to the front of the car. now if in doing so you run out of thread for the nut to travel on, and free play at the pedal is still to big then you have either or both...
1...Too long a cable for your chassis
2... a defect in...
a... pedal cluster hook to which the cab,e is attached, the hook will wear, the metal thin, and the hook will bend, which will give excess pedal freeplay. once the hook gets that thin and bends, it will soon break and fail, so replace it with new.
b... clutch or throwout bearing problems
c... cable conduit problem inside the chassis tunnel, conduit weld(s) broken loose
d... Improper fitting of the bowden tube
e. busted or disconnected return spring on the lever
f. Pedal stop which is on the floor not adjusted right
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
wagen19
wagen19 is offline
PostPosted: Mon Jun 30, 2025 3:32 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
"All 9 (clutch cables) are too short"!?
If it´s that, what you mean.
Have you all of them already tested?
Since when do you have that issue?
As long as your frame and all clutch parts are original and it´s not an issue of loose tube for cable inside of tunnel, or something like that, I suggest to replace the clutch cable regarding the VIN of frame, not body.
As long as the pan has IRS, it must be later than 9´67.
Clutch cables:
The given length are not allways correct. Mine are from the same source for the followig 3 cables listed.
113 721 335 A, 2190 mm, 1´66 - 7´71
111 721 335 C, 2206 mm, 8´71 - 3´74
111 721 335 E, 2190 mm, 3´74 on
BUT:
A 65 beetle had a 2258 mm cable, 113 721 335 what´s a bigger difference.
In 3´74, the IRS trans had got a longer lever for throw out bearing.
2type2
2type2 is offline
PostPosted: Mon Jun 30, 2025 5:43 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
Not 9 cables, typo, 2 diff cables.... Here's what started my confusion, as I'm guilty of over anylizing things;
Quote Bentley manual page 35 Engine section:
"To adjust the cable, raise the car on a lift or support it on safety stands.Grip the clutch cable with a pair of pliers to keep it from twisting, then adjust the wing nut shown in Fig 14-13 until there is 2.0mm ( about 1/4 inch) clearance between the clutch lever and the wing nut. Recheck freeplay at the pedal to make sure it is within specifications. "
Now this is certainly not the first time I have replaced a clutch cable. My memory is such that I always follow a procedure in the book before/while doing it.
* How can it be possible to achieve a 2mm gap at lever -to-nut, when you are tensioning the nut against the arm to pull the arm forward to eliminate excessive freeplay at pedal end? *
This seems physically impossible- what does Bentley mean by this? Tightening the cable to remove slack at pedal can't allow for'" loose space" 2mm at lever.
Cusser
Cusser is offline
PostPosted: Mon Jun 30, 2025 6:10 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
I've been adjusting VW clutch cables for 50 years, and I only was concerned with the free play at the pedal (provided that the bowden tube bend is correct).
Don't forget and leave your Vise-Grip pliers on the clutch cable !!! Ask me how I know this !
Eric&Barb
PostPosted: Mon Jun 30, 2025 7:38 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
Meaning that if someone has a helper push on the clutch pedal that at the rear of the clutch cable the free play should be 2mm.
zerotofifty
PostPosted: Mon Jun 30, 2025 8:42 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
that that 2 mm dimension is that there is to be 1mm to 2 mm between the thrust surface of the throw out bearing and the clutch release plate.
My Bentley states that.... " You can NOT make this measurement directly, but you can obtain it indirectly by measuring the clutch pedal free play. Measured at the pedal, this clearance is 0.4 to 0.8 inch"
So... Ignore that 2 mm measure. What you adjust to is the PEDAL FREEPLAY OF 0.4 TO 0.8 INCH.
This pedal freeplay of 0.4 to 0.8 inch will give you the1 mm to 2 mm play inside the bell house, which is something that you can NOT measure unless you cut a hole inside the bell house.
Again, IGNORE THAT 1MM TO 2 MM MEASURE, You will obtain that clearance of 1 mm to 2 mm at the throwout bearing to clutch release plate WHEN you have adjusted the pedal freeplay to 0.4 to 0.8 inches
Good luck, Enjoy your Bug, lets see some photos of your Bug!!!!
Words to live by.
zerotofifty
PostPosted: Mon Jun 30, 2025 8:45 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
No, that is not correct. that 2mm is NOT the cable free play, rather that is the gap inside the bell house between the throwout bearing surface and the clutch pressure plate ( release plate) See my above post for details.
Words to live by.
rcooled
rcooled is offline
PostPosted: Mon Jun 30, 2025 10:25 am    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
2type2 wrote:
...I'm guilty of over analyzing things.
zerotofifty wrote:
Again, IGNORE THAT 1MM TO 2 MM MEASURE, You will obtain that clearance of 1 mm to 2 mm at the throwout bearing to clutch release plate WHEN you have adjusted the pedal freeplay to 0.4 to 0.8 inches.
Don't over-think it Brick wall zero's post is correct...this is exactly how it's supposed to work.
2type2 wrote:
...until there is 2.0mm (about 1/4 inch)
And for future reference, 2.0mm is about .08"...not .25"
2type2
2type2 is offline
PostPosted: Mon Jun 30, 2025 12:13 pm    Post subject: Re: Clutch cable length for'65 Frankenbug, all 9are too short Reply with quote
Thanks to all for the clarification. I got it together with the shorter cable but it would have helped to use a few more mm's to pass through the arm hole and start thread. Got about 3/8" at pedal.
Sometimes it seems that the J Muir narrative (re: procedure explanations), while often over simplified, keeps one from " paralysis by analysis" in approaching a problem and solution.
