Twistedpair Samba Member
Posted: Mon Jun 30, 2025 10:41 am Post subject: 1973 1300 automatic |
Hi I'm hoping someone can help me.
When I'm driving along, if doing speeds under 35 all is good.
When i get up to 40 there is a loud rattling/banging noise.
Still drives fine and no issues with gears
It has a dry clutch too.
Anyone had this issue and if so what was it?
Thanks
Louise |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1022 Location: half a bubble from plumb
Posted: Mon Jun 30, 2025 12:04 pm Post subject: Re: 1973 1300 automatic |
Howdy ...
Perhaps more info plz :
Does it increase with RPM ?
Only when going over a bump/pot hole ?
Does pushing/pulling on fanshroud help ?
Trying to help ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Tue Jul 01, 2025 10:04 am Post subject: Re: 1973 1300 automatic |
Hi thanks for the reply. It's worse with higher rpm.
No problems with going over potholes etc.
Going to take her out again tomorrow so will try pushing dan shroud to see if that works.
If I get on the accelerator and rev it does it only at high revs. |
Posted: Tue Jul 01, 2025 3:45 pm Post subject: Re: 1973 1300 automatic |
Thanks for more info ...
If occurs at higher revs I'm thinking maybe look at :
Transaxle mounts
CV bolts
Rear bearings
Verify lug nut torque
Axle nut torque
Loose fan belt/pulley
Tire problems
REALLY stretching for possibles ... stay safe
1971 Standard Bug
1776cc dual port
034 distributor
Posted: Wed Jul 16, 2025 4:32 am Post subject: Re: 1973 1300 automatic |
Hi
Turns out it was the flex plate.
The bolts that had been used were shocking and the main bolt was not torqued!!
All up and running now and mot's |
