Breather Oil Filler Cap?
GTV
GTV is offline
PostPosted: Fri Jun 24, 2011 8:50 am    Post subject: Breather Oil Filler Cap? Reply with quote
I'm looking for an oil filler cap that allows the engine to breathe, and fits on the stock VW oil filler. I see ones for V8's at every parts place, but nothing that fits the VW. Anyone??
EMPI Power Rules!
torsionbar
torsionbar is offline
PostPosted: Fri Jun 24, 2011 9:19 am    Post subject: Re: Breather Oil Filler Cap? Reply with quote
huh? the factory vw oil filler already has a breather tube. depending on year, it either vents downward into the air stream under the car, or it vents upward through a hose and into the air cleaner.
post a photo of your engine here. i'm guessing you probably have parts missing, or have some crappy aftermarket filler w/o a breather?
GTV
GTV is offline
PostPosted: Fri Jun 24, 2011 2:01 pm    Post subject: Reply with quote
Not exactly, it's a new build.
I'm venting the 1-2 valve cover to the breather fitting on the stock oil filler, and I'm using the filler that doesn't have the draft tube because I don't like them (designed to leak, designed to fail, IMO). Plus the engine just looks simpler/cleaner without it.
I can't vent to my aircleaners because I wont be running any Smile
EMPI Power Rules!
rays-64
rays-64 is offline
PostPosted: Fri Jun 24, 2011 3:18 pm    Post subject: Reply with quote
http://www.cbperformance.com/catalog.asp?ProductID=729
something like this.
rays-64
rays-64 is offline
PostPosted: Fri Jun 24, 2011 3:20 pm    Post subject: Reply with quote
forgot to add, that you would have to run breather box with this and your set-up
GTV
GTV is offline
PostPosted: Fri Jun 24, 2011 3:41 pm    Post subject: Reply with quote
Thanks for the link, but I'd like to retain the stock filler/breather since this is a period correct sort of build. Billet parts are also out.
EMPI Power Rules!
slalombuggy
slalombuggy is offline
PostPosted: Fri Jun 24, 2011 4:08 pm    Post subject: Reply with quote
I just spent the afternoon working on a 57 Fairlane Skyliner. the oil cap was a chromed, dome style breather cap with two spring clips sticking out the bottom to hold it into the valve cover. You might find something like that to use.
brad
GTV
GTV is offline
PostPosted: Fri Jun 24, 2011 4:23 pm    Post subject: Reply with quote
brad
Those are very common, and would be perfect for my application but unfortunately they do not fit the VW filler.
EMPI Power Rules!
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Fri Jun 24, 2011 6:00 pm    Post subject: Reply with quote
SCAT shows two types in it catalog.
Dome one#80084
Flat top style #80330
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
TURBOEDVW
TURBOEDVW is offline
PostPosted: Fri Jun 24, 2011 6:21 pm    Post subject: Reply with quote
Like this?
Vented Oil Filler Tube w/ Screw-on Cap
http://www.dansperformanceparts.com/buggy/osc/buggyosc2.htm
GTV
GTV is offline
PostPosted: Sat Jun 25, 2011 9:02 am    Post subject: Reply with quote
Dome one#80084
I saw that and called Scat about a month ago, the guy said they hadn't had those caps in months, maybe years. I did pick up a NOS "chrome dome" cap here on the samba a few weeks ago, but unfortunately it's sealed.
Does anyone know if a breather style cap was ever made as a replacement for the stock cap?
EMPI Power Rules!
GTV
GTV is offline
PostPosted: Sat Jun 25, 2011 9:03 am    Post subject: Reply with quote
vwonnos wrote:
Like this?
Thanks for the link, but no, that replaces the oil filler as well. I want to retain the stock oil filler, just replace the cap.
EMPI Power Rules!
chrisflstf
chrisflstf is offline
PostPosted: Sat Jun 25, 2011 9:13 am    Post subject: Reply with quote
Berg sells breather boxes with a breather cap. I believe the cap fits the stock oil filler. give them a call
GTV
GTV is offline
PostPosted: Sat Jun 25, 2011 9:38 am    Post subject: Reply with quote
I already did. Berg offers breathers that use the stock cap, and the domestic style breather cap.
EMPI Power Rules!
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Jun 25, 2011 10:53 am    Post subject: Reply with quote
Why not just make one?
GTV
GTV is offline
PostPosted: Sun Jun 26, 2011 7:52 am    Post subject: Reply with quote
Ok, any ideas on how to go about that?
EMPI Power Rules!
Randy in Maine
PostPosted: Sun Jun 26, 2011 8:04 am    Post subject: Reply with quote
I would just buy one for a V8 and make it so that it would fit a VW.
But that is just me.
GTV
GTV is offline
PostPosted: Sun Jun 26, 2011 7:06 pm    Post subject: Reply with quote
That has crossed my mind... I'll pick one up this week and give it a shot... at least they're cheap.
I'll let you know how it goes...
EMPI Power Rules!
Cusser
Cusser is offline
PostPosted: Thu Jul 10, 2025 6:24 am    Post subject: Re: Breather Oil Filler Cap? Reply with quote
I run a press-on breather cap (came with the oil fill extender) I bought in the 1970s on my 1835cc engine. I cannot remember the source.
