Nicklastl Samba Member
Posted: Wed Jul 09, 2025 11:49 pm Post subject: Type 4 smog? |
Hey guys
Currently in process of rebuilding my 1700 type 4, and I’m not sure what to do about these “smog” lines?
The previous owner had the lines welded together. See pictures l Can somebody please explain what they do and why someone would blind them off?
What would be the best thing to do?
It’s going back in a bay bus
Beat regards
_________________ '73 Westfalia Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=794180&highlight= |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52691 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 10, 2025 7:49 am Post subject: Re: Type 4 smog? |
There once was an air pump driven off the crank that pumped air into those to burn pollutants in the exhaust.
The solution is a M10 x 1.0 hex drive pipe plug, or valve adjuster screw. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Yesterday 12:33 am Post subject: Re: Type 4 smog? |
busdaddy wrote: |
The solution is a M10 x 1.0 hex drive pipe plug, or valve adjuster screw. |
Thanks så det best thing to do would be just to Block them off? _________________ '73 Westfalia Project
Posted: Yesterday 6:44 am Post subject: Re: Type 4 smog? |
Nicklastl wrote: |
busdaddy wrote: |
Thanks så det best thing to do would be just to Block them off? |
Yes, screw in the pipe plugs or valve adjusters to block the holes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
