Franklinstower Samba Member
Posted: Sun Jul 13, 2025 2:25 pm Post subject: Sunroof adjustment at the rear |
Hey knowledgeable peeps,
I was working on my '75 Standard Beetle today, took the sunroof out, cleaned it up, put in new sunroof seals and encountered an issue that I can't figure out how to resolve. I have all the adjustments done and noticed the right rear doesn't pop up into the full "locked" position. IE: the "pop up" mechanism on the cable doesn't go to a full 90° leaving that right rear slightly lower than the left side when the sunroof is fully closed.
Pictures for clarity:
Drivers side:
Passenger side:
So what is the trick to fixing this? It is as if the right side cable is a tooth or two off, but would that really matter? If I try to really close it hard with the crank, I will just skip a cable tooth and it doesn't go any further to 90°.
Previewing this, I noticed the position of "pop up" mechanism on the right is about 3/4" further back on the leaf spring compared to the left side. Is this indicating the right side cable is not adjusted/installed correctly?
Any help is appreciated.
Thanks.
Paul[/b] _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11786 Location: Redding, CA
Posted: Sun Jul 13, 2025 10:10 pm Post subject: Re: Sunroof adjustment at the rear |
The lower pic seems to show the leaf spring not fully engaged with that barrel.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52713 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 14, 2025 7:26 am Post subject: Re: Sunroof adjustment at the rear |
Cable timing does matter.
If it refuses to go over center to vertical loosen that nut and move it down in that slotted hole a little, both lifters should be synchonised and forcing it so it skips is asking for trouble. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 14, 2025 7:51 am Post subject: Re: Sunroof adjustment at the rear |
I think I figured it out. I measured the cable distances on each side and the right side was further back than the left, so the "cable timing" was out of adjustment. I got the two sides into alignment, bent the little metal tabs under the plastic cover to hold more pressure onto the cog wheel and I believe that will correct my issue. It got to hot in the sun yesterday afternoon, I will finalize this later today, much cooler in the NW today. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
YITB |
