What is tihs part? SOLVED
pgiraud
pgiraud is offline
PostPosted: Mon Jul 14, 2025 5:14 am    Post subject: What is tihs part? SOLVED Reply with quote
Hello,
I bought a 1956 oval window beetle (with a ragtop). It was left "to be reassembled" by the previous owner.
Can someone please tell me if this piece of painted metal a part of the vehicle? Where does it go?
Could it a part from a different car?
Could it be related to the ragtop mecanism?
Thanks
vw356
vw356 is offline
PostPosted: Mon Jul 14, 2025 5:31 am    Post subject: Re: What is tihs part? Reply with quote
This part is not for the sunroof. It is a cover for the front hood release mechanism. The "U" shaped cut out is where the end of the metal tube that holds the hood release cable fits.
Current projects:
1950's Volkswagens!
51,52,54's,55,56's,57,58's,'60's And then a bunch of '60's, but the '50's are my favorites..
pgiraud
pgiraud is offline
PostPosted: Mon Jul 14, 2025 5:38 am    Post subject: Re: What is tihs part? Reply with quote
Indeed!
Thank you very much for you quick answer.
banana split
banana split is offline
PostPosted: Mon Jul 14, 2025 10:42 am    Post subject: Re: What is tihs part? SOLVED Reply with quote
Here you can see it installed (black piece) :
My Beetles :
1953 Zwitter
1964 Chop Top
djfordmanjack
djfordmanjack is offline
PostPosted: Tue Jul 15, 2025 12:23 am    Post subject: Re: What is tihs part? SOLVED Reply with quote
yes it needs to be black, not body color !
54 Oval project
62 Dickholmer, Seeblau L360
pgiraud
pgiraud is offline
PostPosted: Tue Jul 15, 2025 1:00 am    Post subject: Re: What is tihs part? SOLVED Reply with quote
Thanks @banana split for the photo, and @djfordmanjack for the info about the color.
By the way, if I compare the lock mechanism between my 58 and my 56 oval, I see a small difference. One is attached to the front apron with 4 bolts (58'), the other with only 3 bolts (oval).
Is that correct?
djfordmanjack
PostPosted: Tue Jul 15, 2025 2:03 pm    Post subject: Re: What is tihs part? SOLVED Reply with quote
no it's the other way around ! old version is 4 bolt, new one is 3 bolt. my 54 has 4 bolts. Maybe something has been replaced on your cars. I am not 100% sure but since a 58 still has basically parts of the oval front body, it could also have a 4 bolt hood latch, my 61 has a 3 bolt.
54 Oval project
BulliBill
BulliBill is offline
PostPosted: Wed Jul 16, 2025 8:01 am    Post subject: Re: What is tihs part? SOLVED Reply with quote
"djfordmanjack" is right on the money. You should have a "four finger" style front apron with four sloted holes for a four bolt hood latch/catch mechanism with that black cover on your Oval. Many Ovals had acident damage or rust over so many decades of use and a previous owner may have bought what was available back then (later style two or three finger front apron) to repair the damage.
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
