namvet6872 Samba Member
Posted: Mon Jul 14, 2025 1:45 pm Post subject: Lift points |
Which lift point would be the safest location? I want to raise rear end on a recently purchased '63 Beetle. My first classic and don't want to break something. I've found conflicting answers while searching.
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 296 Location: Eastern north carolina
Posted: Mon Jul 14, 2025 2:30 pm Post subject: Re: Lift points |
I have always used (50 plus years) the small circled wishbone area with a block of wood between it and the jack. In the rear the bottom of the shock housings is also good if you want 2 points. Good luck-Bob |
shano63  Samba Member
Joined: October 06, 2006 Posts: 3634 Location: Stormville NY
Posted: Mon Jul 14, 2025 3:26 pm Post subject: Re: Lift points |
I have always used the bigger circle. So, take your pick..lol _________________ 63 T1 Ragtop Gulf Blue
20 Toyota Corolla 6spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
Posted: Mon Jul 14, 2025 3:41 pm Post subject: Re: Lift points |
Thanks guys, at least I now know that either spot will work... |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6100 Location: 37.5N 77.1W
Posted: Tue Jul 15, 2025 7:45 am Post subject: Re: Lift points |
I use the bottom shock 'arms' or under the torsion bar 'plates'. Then again I use two jacks. When I only had one, I put it under the Y 'Yoke' but it ended up getting dented that's why I started using two jacks. Never jack it up using the engine/transaxle cross support. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Tue Jul 15, 2025 11:16 am Post subject: Re: Lift points |
Thanks for the warning, Runamoc... |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11040 Location: Oregon
Posted: Tue Jul 15, 2025 11:28 am Post subject: Re: Lift points |
namvet6872 wrote: |
You can use the yoke jacking point just forward of the trans to lift the car.
The trick is, place a 1.5' 2x6" on the floor jack center pad, to spread the load.
I do that all the time when I need to get under one of my beetles. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17583 Location: Left coast, Canada
Posted: Tue Jul 15, 2025 4:12 pm Post subject: Re: Lift points |
shano63 wrote: |
I have always used the bigger circle. |
This is why it's common to find the rear trans bracket all bent up. _________________
Posted: Tue Jul 15, 2025 4:48 pm Post subject: Re: Lift points |
So, why is this so wrong? I've had my car for 30 plus years and no issue that I'm aware of. _________________ 63 T1 Ragtop Gulf Blue
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
EVfun  Samba Member
Posted: Tue Jul 15, 2025 4:49 pm Post subject: Re: Lift points |
Bruce wrote: |
shano63 wrote: |
This is why it's common to find the rear trans bracket all bent up. |
Yes, but I can buy another one using the classifieds here on theSamba. It is a bit more of a PITA if you bend the frame tunnel under in front of the torsion housings. _________________
Wildthings wrote: |
Posted: Tue Jul 15, 2025 6:26 pm Post subject: Re: Lift points |
Just to the rear of the small circle in the op photos with a stout wood block like 2x8 where you span the 2 rear horns will not bend anything and has worked for me for over 50 years. |
Bruce Samba Member
Posted: Wed Jul 16, 2025 12:28 am Post subject: Re: Lift points |
EVfun wrote: |
Bruce wrote: |
shano63 wrote: |
Yes, but I can buy another one using the classifieds here on theSamba. It is a bit more of a PITA if you bend the frame tunnel under in front of the torsion housings. |
It's easier to use a piece of wood as described above to spread the load at the front of the trans than it is to replace the rear trans bracket. _________________
