CB 2242 Cam and Compression ratio for 1776cc
TheRookie
TheRookie is offline
PostPosted: Mon Jul 14, 2025 2:50 pm    Post subject: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
Hi Guys
I have CC'd my heads and it's at 51cc with a deck height of 1mm well slightly under. I calculated my Compression ratio at 8.9:1
Hoping this will be enough for my 1776cc to take full advantage of the 2242 cam
Engine specs
1776cc
Cw crank
041 heads bowl blended port job
Scat 1.25 rockers
36 Dells /30 vents jetted accordingly
Im hoping for 100HP from this engine
jeffrey8164
jeffrey8164 is offline
PostPosted: Mon Jul 14, 2025 3:36 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
Seems great, especially with the rockers.
Volkswagen!
(Compression 8.7:1)
Rob Combs
Rob Combs is offline
PostPosted: Mon Jul 14, 2025 9:31 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
CB recommended 9.0 when i got my 2242.
I don’t know if you’ll notice the difference between 8.9 and 9.0:1.
TheRookie
PostPosted: Mon Jul 14, 2025 11:41 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
Thanks Guys
My 1st time building a performance engine ,well sort of .I was an engine I bought that im fully reconditioning and took it from 1835cc to 1776cc
TheRookie
PostPosted: Mon Jul 14, 2025 11:45 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
I'm sure anything over 8.5 should be good
BFB
BFB is offline
PostPosted: Tue Jul 15, 2025 4:41 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
Im sure 8.9 will be fine, but if it was me, and your wanting to hit / break the 100hp mark then id flycut the heads and bump the compression up.
Most experts aren't.
StefansBus
StefansBus is offline
PostPosted: Tue Jul 15, 2025 11:53 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
TheRookie wrote:
Hi Guys
I have CC'd my heads and it's at 51cc with a deck height of 1mm well slightly under....
A tight deck is great but 1mm or less probably too tight.
Regarding compression: Depending on your typical ambient conditions and available fuel I'd rather be a bit above 9:1 instead of below with that cam. It'll work fine with 8.9:1 but you may be leaving some power on the table. I run 8.9:1 with an old 2239. My deck is around 1.25mm if I remember correctly.
Rob Combs
PostPosted: Wed Jul 16, 2025 9:50 am    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
[quote="StefansBus"]
Interesting point here. While CB recommended 9.0 for my 2242, I've also been recommended (not by CB) to run 9.0 with the 2239 I had initially decided to run.
My 2239 cam card states 240* at .050", and my 2242 cam card states 252* at .050". I verifed the 252* at one of my recent mockups.
Now that you bring it up, it does strike me as a little strange to have the same 9.0 recommendation with cams this far apart in running duration.
It's likely that in my head I'm not correcting for all of the variables, however...
Just another idea for the OP to consider. I think we all want him to get the most he can out of his project, within whatever practical constraints he's facing.
TheRookie
PostPosted: Wed Jul 16, 2025 1:57 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
Hi Guys
I dont have much access to lathes and milling machine but the plan is to lap the jugs to the heads and hopefully get some 1000th of mm from that.
More so I ve watch videos regarding 041 heads and majority of them measured at 50cc's
Alstrup
Alstrup is offline
PostPosted: Wed Jul 16, 2025 4:26 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
TheRookie wrote:
Hi Guys
That depends heavily on the actual model. The old 041´s were rated 52-54 cc. and of the lot I have measured that holds. Then comes the newer "GO3) 041´s. There are 2 models from waht I have seen. One model which stays about true to the old Brazil version, and a later one which typically has 56-57 cc chamber volume. So, once again, CHECK, do not assume.
Wrt CR. 8,9 static is ok for the cam. Personally I would have liked a hair more to get more usable torque, but if youre good with setting up a nippy timing curve along with having a good ignition capacity, you can somewhat make up for that slightly low compression.
Your deck height/squish quality is more important than the last digit in static compression, so be on top of that.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
BFB
BFB is offline
PostPosted: Wed Jul 16, 2025 7:31 pm    Post subject: Re: CB 2242 Cam and Compression ratio for 1776cc Reply with quote
Depending on OP’s driving preference, could always advance the cam
